Could anyone can help with solution for this problem?
Your best bet would be to investigate termX relay.
The relay panel is located above main fuse panel
left of pedal cluster.
You will need to remove screw, un-clip and lower panel. TermX relay is top most to the left. Swap relay with known working one.
