Questions about the PSE Hack on a 3.4
Moving to my question, who here has done the PSE Hack? It seems like a good medium for me. I love the sound in the clips I have heard.
The problem is, I have the 3.4 exhaust. The general consensus is that the sound improvement is not so great on the 3.4 cans as opposed to the 3.6's (when doing the MKII mod).
From what I understand:
-MKII mod (3.6) - There is a 2 1/4 pipe from bypass to outlet [see pic1]
-MKI mod (3.4) - A small bypass pipe is cut in, between the inlet and outlet of the muffler [see pic2]
So since I want a noticeable difference, I figured I should go with the MKI mod. I have seen tons of feedback on the MKII mod, but very little on the MKI mod. The only person I found who did it was here: https://rennlist.com/forums/996-foru...haust-mod.html
He used 1 1/4 pipe between the inlet and outlet. I am just wondering if anyone else has done this, and what are your results? Have you used the same sized piping? Will a larger diameter pipe produce more sound?
And can I bring this to any muffler shop and have it done?
Thanks alot!
ps - for anyone who wants to learn more about the "pse hack," this thread has everything you need to know: https://rennlist.com/forums/996-foru...-real-pse.html
Thanks alot!
I found a set of 3.6 cans (in very good shape, dont buy junk just because "you fouond some") I had them modded, and swapped them in.... then sold the 3.4 cans for a fair price to someone that wanted them.
FisterD is great, but be aware.... its not cheap, he is running a business and that is just how it is. If you do it yourself (or local muffler shop) you run the risk of getting a lesser quality job, but it might cost less. I had a friend who owns a tubing shop do mine for a "favor" and I bought him lunch and some beer....unless you weld, that is the only options (and by "weld" I mean weld really good, not make sparks and have the parts kinda stick together)
LINK
read post #520 and #525 -----
PS... they are NOT loud, I had the bypass pipes first. This is the way to go!
). If you take it to a muffler shop, be sure they use stainless pipe and weld it with stainless. If not, it may sound good for a while...but rust never sleeps. And on a 911, with the exhaust sitting right behind the rear wheels, it can get ugly. I use larger then 1 1/4" piping, and it sounds great.
). If you take it to a muffler shop, be sure they use stainless pipe and weld it with stainless. If not, it may sound good for a while...but rust never sleeps. And on a 911, with the exhaust sitting right behind the rear wheels, it can get ugly. I use larger then 1 1/4" piping, and it sounds great.Hey Fister. I have only heard good things about your work! Thanks for chiming in. What size piping do you suggest I use? I was thinking of going with 1 1/2" to do the MKI (aka stage II). I will deffinitely be going with stainless steel.
Also, do you suggest I just a U shaped pipe online to it can be cut in half and used by the welder? Or should I just go with whatever piping they have? I'm assuming they could bend it without too much trouble.
