6 Speed Transmission Issues...
06-08-2009, 07:34 PM
First Gear is Whining (Like a Reverse Gear)... and Going from 2nd to 3rd past 6k RPM it Grinds...
06-08-2009, 09:07 PM
When did it start doing this Zook?...today?...
06-08-2009, 11:06 PM
Sounds like a bearing and synchro replacement is a comin'.
Quote:
Originally Posted by
Zookie
06-09-2009, 09:09 AM
Zookie!
Mine was whining in every gear when coasting, even in neutral while rolling.
It's in the shop now for a complete rebuild.
Good luck with yours.
Pete
06-09-2009, 12:37 PM
pongobaz
The 3rd Grind is been going on forever, it was doing it more yesterday... And the whine in 1st started on my way home...
pszikla
Well i think CPO Should cover it
06-09-2009, 12:54 PM
Did you check the fluid level?
06-09-2009, 01:07 PM
Tippy
All you can do is fill it up through the fill hole until it starts to spill back out, right?
06-09-2009, 04:41 PM
SearedRennlist Member
Whitey||C4S
Correct.
Andreas
06-09-2009, 07:11 PM
06-10-2009, 08:18 PM
Ouch. What could the repair cost be on this problem?
06-10-2009, 08:23 PM
$3700+
ryangambrill
06-11-2009, 05:56 PM
washington dc porsche
$3700+
Is that to Rebuild one? My Service tech thinks its a Bent Gear...
06-11-2009, 06:42 PM
Basically. Vertex has rebuilds for $3500. Then of course your removal and install price from your local indy.
Zookie
06-11-2009, 10:56 PM
18 ,
1st ,
2004 ,
996 ,
c4 ,
gear ,
grinding ,
issues ,
jetta ,
noise ,
problems ,
speed ,
teardown ,
transmission ,
volkswagen
