996 Forum 1999-2005
ABS/PSM Lights
Old May 22, 2009 | 10:26 AM
SKooT1027's Avatar
SKooT1027
Default ABS/PSM Lights
*Update - Post 12*
I've gotten the ABS and PSM lights on a couple times this week when I first start the car. Usually restarting it will cure it. It doesn't feel any different. Anything I should be looking for/at?
Old May 22, 2009 | 10:53 AM
an02boxster's Avatar
an02boxster
I have had that with a bad MAF. If you start your car with the MAF unplugged they will be on also.
Old May 22, 2009 | 11:15 AM
rideau's Avatar
rideau
Same issue.....loose MAF was the reason
Old May 22, 2009 | 11:33 AM
SKooT1027's Avatar
SKooT1027
Okay thanks. I'll try popping it out and back in and see if that fixes the problem.
Old May 22, 2009 | 11:52 AM
chsu74's Avatar
chsu74
Scott,
MAF's go bad around your mileage/years in use.
This is the cheapest I have found for replacement.
http://www.autopartsworld.com/porsch...eter/2002.html
Old May 22, 2009 | 11:55 AM
SKooT1027's Avatar
SKooT1027
Chao - Wouldn't a bad MAF throw a CEL or something emission related? Also, it only seems to come on when I start the car and immediately drive (running late to work) or hit all kind of electronics (immediately take top down, play w radar and radio). If it doesn't come on within those first few seconds, it doesnt come on at all, and it hasnt come on if I restart the car.
Old May 22, 2009 | 12:30 PM
chsu74's Avatar
chsu74
My bad MAF never did. It threw ABS and PSM lights. It will continue like this until one day the lights will just stay on until you replace the MAF.
Do a search and most people experienced this issue with these symptoms. Of course there may be other reason but unless you have a durametric, it is hard to tell.
Old May 22, 2009 | 12:37 PM
SKooT1027's Avatar
SKooT1027
Okay thanks. I'll start by just popping it out and reconnecting it to see if it's just loose. Otherwise I'll have to pick up a replacement
Old May 22, 2009 | 09:35 PM
leia7987's Avatar
leia7987
Scott,
I just bought mine off ebay for 235 shipped, also if you have a live.com account you can get 8% off any buy it now on ebay. If you need instructions on the live.com pm me.
Old May 23, 2009 | 04:18 AM
pete95zhn's Avatar
pete95zhn
Former Vendor
Mine ignited ABS & PSM lights under hard accaleration. Last week I replaced that K&N with OEM filter and cleaned the MAF with MAF cleaner spray. No more warnings.
Old May 23, 2009 | 05:37 AM
JDSStudios's Avatar
JDSStudios
ABS and PSM was MAF for me too.
Just cleaned the MAF and Throttle body (12 minutes to do that and blow the air filter too)
has been running fine since.
Old Jun 12, 2009 | 01:44 AM
Aerkuld6's Avatar
Aerkuld6
You could also try the brake light switch in the pedal cluster. That cured my ABS / PSM warning light problem.
Old Jul 20, 2009 | 11:09 AM
SKooT1027's Avatar
SKooT1027
Finally got around to replacing the brake switch this weekend. For starters, it took me way longer than it should have. The new switch came with the button extended out too far. This prevented me from twisting it in and locking it in place. After multiple cuts on my hand and curses while laying upside down in the drivers footwell, I noticed that the switch can be pressed down so it doesnt extend quite as far. It then twisted in nice and easy.
It didn't fix my occasional starting problem (obviously, since you dont need the brake to start the car), but it does seem to have fixed my PSM/ABS lights. It's been 2 days and no lights. Can't complain about a $25 fix (bought it through the dealer so I didnt need to wait for it to get shipped).
I'm going to pick up a clutch switch to see if that fixes the starting problem, otherwise will try ignition switch next. If neither work, I'll have my mechanic take a look.
So if you have a similar problem, start with the brake switch before going after the MAF or anything else more expensive
Old Jul 20, 2009 | 12:44 PM
wwest's Avatar
wwest
Battery...
