View Poll Results: What should I do with it?
Go with a set of H&R springs and shocks.
8
22.86%
Get a set of el-cheapo coilovers.
2
5.71%
Wait on a set of quality coilvers that are for sale by a fellow P-car.
18
51.43%
Don't lower it any!
7
20.00%
Voters: 35. You may not vote on this poll
Drop it like it's hot?
So this is the progress so far on my new to me 996. I am looking for a more aggressive "Look" suspension. I seriously doubt I will ever track this car. This is just about my daily driver; I drive my truck a couple of times a week but mostly my 996. I drive somewhat aggressive at up to 80-100mph daily but few turns. 25 miles each way to work. I have 6 speed bumps to cross in my neighborhood.
I have searched till my eyes bleed and can not decide on what is best.
Here are the reasons I am asking your opinion:
Factory Aero kit
19" rims...19x11 on rear(if it matters)
C4 cab.
Btw I don't want to spend over 1k for suspension. I would love a set of Pss9's but are too much for what I need. Maybe a used set if I could find them.
Factory Aero kit
C4 cab.
Two pairs ($750 & $1000) of used GT3 adjustable coilovers:
https://rennlist.com/forums/showthre...ferrerid=45672
It would look much better lowered. However, you might have rubbing issues because it looks like your rear wheel offset is pretty aggressive from this angle.
Not all regions are the same, though. Sure, some are very active, but others are simply a social club with few other activities, and little incentive for someone to join. 20 years ago, it may have been the only place to get together with fellow Porsche owners and chat p-cars, but today, we have the internet for that.
Yes, and the set I'm selling is local to him!
And it just so happens, I'm also selling an Eibach suspension as well...
I agree jmla!
Thank you, jmla for reminding me about this. And I agree, if you can own a P-car, you can afford a M-ship. :-)
I think if you're going to go out and spend money installing, and the concern is ride height, you might as well do the PSS9s, you should be able to find a deal on a set here or 6 speed. Incremental cost to the RoW M030 is probably going to be 500 to 700 bucks. Being able to adjust the height eliminates the risk of going so low that you rub if rear offset is maxed out.
I don't know why you're lowering exactly, but FWIW if it's a street car I think it's a waste of money, unless you are doing it yourself (you'll need a spring compressor for the PSS9s), at which point hey whatever.
It looks like you've got 19" wheels on a car designed for 18s, if so those wheels and tires are probably larger than the stock diameter. You may want to consider keeping the current suspension to avoid wheel arch damage from a bad pothole, which I've seen happen to a number of lowered cars with oversize wheels. Your car would probably be at risk, since the suspension geometry was designed for factory wheels up to an 18" diameter and this is your DD. My $.02.
