19inch HRE wheels ...need help
hi i am trying to upgrade to HRE 19 inch wheels but need to know if these will fit my narrow body..... front wheels are 8.5JX19, offset 51mm and the rears are 11JX19, offset 45mm......
Fronts will fit, technically you could even push them out another 10mm
rears are toooo wide for a stock narrow body. Honestly they are a little wide for a widebody but still OK. again i have no clue what your fenders actually look like due to the conversion, so I can't be of much help, but you're looking at about 63mm offset being the max for a stock stock narrow body 996 for an 11 inch rear. 45 is 18mm, or 2/3 of an inch over.
I don't know much about rolling fenders on these cars, but you can ask a local shop. Depending on how much material you have to work with at the hub, a combination of rolling fenders and grinding the wheel hub might get you to an acceptable appearance, but it's risky, and I personally would not recommend it. If you can get those wheels in a narrow body offset you should.
Newbies Hospitality Director
Front wheels will fit, but rear wheels will not. They wil stick out 33mm more than a stock 10" wheel with 65mm offset. The wheel itself will be beyond the fender well and look something like this.
