996 Forum 1999-2005
CEL 1118
Old May 18, 2009 | 02:02 PM
SH || NC's Avatar
SH || NC
You can Google "OBD2 drive cycle" to get various answers. Here is one.
Link
RUNNING AN OBDII DRIVE CYCLE
Suppose you've "fixed" an emissions problem on your OBDII-equipped vehicle. How can you check your work? By performing what's called an "OBDII drive cycle." The purpose of the OBDII drive cycle is to run all of the onboard diagnostics. The drive cycle shold be performed after you've erased any trouble codes from the PCM's memory, or after the battery has been disconnected. Running through the drive cycle sets all the system status "flags" so that subsequent faults can be detected.
The OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another).
NOTE: The ignition key must not be on prior to the cold start otherwise the heated oxygen sensor diagnostic may not run.
1. As soon as the engine starts, idle the engine in drive for two and a half minutes with the A/C and rear defrost on. OBDII checks oxygen sensor heater circuits, air pump and EVAP purge.
2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. OBDII checks for ignition misfire, fuel trim and canister purge.
3. Hold at a steady state speed of 55 mph for three minutes. OBDII monitors EGR, air pump, O2 sensors and canister purge.
4. Decelerate (coast down) to 20 mph without braking or depressing the clutch. OBDII checks EGR and purge functions.
5. Accelerate back to 55 to 60 mph at ¾ throttle. OBDII checks misfire, fuel trim and purge again.
6. Hold at a steady speed of 55 to 60 mph for five minutes. OBDII monitors catalytic converter efficiency, misfire, EGR, fuel trim, oxygen sensors and purge functions.
7. Decelerate (coast down) to a stop without braking. OBDII makes a final check of EGR and canister purge.
Old May 18, 2009 | 02:38 PM
1999Porsche911's Avatar
1999Porsche911
Any good scanner will show all emission sensors that are not in ready mode. If any are indicated, you will not pass emissions.
Old Jul 3, 2009 | 11:20 AM
aben8057's Avatar
aben8057
I cleared the code and P1118 came back on. This is an intermittant problem as in comes on and off. I did observe that when my tank is half full, it comes on. I guess it is time to change the sensor. Does anyone know exactly where the location is? drivers or pass side?
Old Jul 3, 2009 | 01:46 PM
springgeyser's Avatar
springgeyser
Physically, it is located on the driver side after the cat.
I found that one of my secondary o2 sensor just had a bad connector so once I bypassed it, the code went away. Of course, I wasted time swapping in new sensors to find out.
