Wheel spacer sizes and driving impact
I've done multiple searches on this issue and can't seem to find enough info in one spot to draw a consistent conclusion. Question are the optimum wheel spacers front and rear to use for a stock 2001 996 18 inch wheel C2 daily driver to give the "best look" without detriment to driving? I may want to lower ths suspension later. I've heard 7mm front and 15mm rear and then the opposite...?
Parts Specialist
opposite AND some run 15's up front too...
I think if you ran a poll though you would find 15 front - 7 rear is mostly regarded as the "best" and there would be other opinions....
Newbies Hospitality Director
Get one pair of each (7mm & 15mm) but MAKE SURE you got the longer bolts need to fit for each size.
Then install one side 7 front and 15 rear and the other 15 front and 7 rear. Then decide what looks best to you and change the one side to match your preferred look. That way you are changing only one side a second time.
As far as detriment to driving, what do you mean by that?
-td
Actually ivangene's backwards, but since he posted before me, apparently I fall into the "other opinions" column.
The rear is perfect, although 15 front would be great too.
for the pros and track ******... they can def tell the diff if they are tuning their car... but to us common folks, its fine either way.
I am almost 100% certain that most people will not be able to tell a 14mm difference in the front on a street car. And on the track, 14mm wider in the front might actually help the car...
-td
Parts Specialist
I have them backwards BUT have winter tires on so I am reserving my final opinion till spring when I swap wheels/tires
Till then I just drive in reverse but since I have so many miles the DMV won't care if I remove a few
Spacer width also needs to factor in the rim width+offset and tire sizing for proper clearance.
for me-
Street- 15f 23r on 7"(55et) & 9"(55et). 225/255 tires.
AX (planned)- 15f 23r on 9"(52 et) & 10"(65et). 265/285.
Track- no spacer on 9" (46et) & 11" (63et). 255/295.
for me-
