battery info for 996
I am at the point I need to replace my battery in the 99, 996 cab. I am trying to decide which way to go. Several people told me interstate MTP91 ($150.00) others say OP red top ($189.00)...others say stay original (part #99961108020) ($210.00) not sure original is worth the money not sure what mods are need for the other choices. I can buy a new Porsche brand battery part # 99961108820 but not sure, it will fit. Any advice, especially regarding the 99961108820?
Here's a link to my Optima install about 2 years ago
https://rennlist.com/forums/996-foru...a-battery.html
Yellow Dog sells a plastic or aluminum mounting plate. FWIW I like my Optima, pretty much problem free. I did have a battery draining issue but it had nothing to do with the Optima. Turned out to be the interior lights.
Another option for even more weight savings is an Odyssey battery.
Just bought a 49-1 from Wally world...$69! Bought a battery tender w/float from Harbor Frieght $8(?) Been accused of being cheap, but I prefer frugal...afterall I own a Porsche with money I've saved
Having just taken my battery out, I can tell you that there are several "mounting spots" for the bolt-down bracket. This should mean that you can use a battery of a different length - as long as the terminals are on the right sides.
By all means, DO NOT waste your money on a Porsche battery. I have made that mistake in the past. The last one made it less than 2 years! Yes, I use a battery maintainer.
I recommend the Interstate Battery #MTP-H7. This is the DIRECT replacement in terms of size and location of the vent hose attachment point. You will NOT need the vent hose adapter kit. It uses one of the existing clamp points on the battery tray. It's an 800 amp (640CCA) battery compared to the stock Porsche's 380. The engine turns over much faster then before.
It also comes with an 85 month no-questions asked warranty. The Porsche one does not.
