What will reduce understeer
It should also be noted that Trailbraking shouldn't really be practiced on the street either. You could practice pedal feel if you wanted to on the street but to really get it to work right you need to be way beyond the level you should be driving at on the street.
That's why for street driving throw a big rear bar on the car and take away some grip at the rear and you'll move balance to the front that way for better "general" feel. Doesn't necessarily mean you'll be any faster at the track but it'll feel better on the street. When I had just H&R springs on my car I ran a M030 front sway with a GT3 rear sway and I really liked the way the car drove.
Parts Specialist
isn't oversteer the *** coming around...in otherwords LESS rear traction?
Sorry to keep this up, but for me its an area I dont know much about and this is great info (not that it will change my driving to and fro work
....and just the opposite for understeer.
The reason it is not a 1 to 1 scenario and not a "when increasing one the other decreases" is because there are more variables involved with trying to achieve "balance" between the two when taking corners.
Ironman 140.6
lots of stuff:
Higher front tire pressure
Lower rear tire pressure
Larger front tire section
Smaller rear tire section
More negative front camber
More positive rear camber
Softer front springs
Stiffer rear springs
Thinner (weaker) front sway bar
Thicker (stronger) rear sway bar
Weight distribuation more rearward
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Parts Specialist
To the OP, where are you experiencing understeer? At corner entry? Midcorner? Exit? All through the corner?
Despite the street tendency towards understeer, I would first look at your driving technique before fiddling too much with the setup. It is possible that you are exacerbating the inherent understeer by abrupt release of the brakes or a heavy right foot.
Depends on a number of factors, including the car, what gear you are in, and the corner. But in a 996, a heavy foot too early in the corner can result in corner entry understeer because of decreased front tire patch due to rearward weight transfer. This coupled with poor braking technique can wreak havoc on your corner entries. In other instances, a heavy throttle can result in throttle oversteer - which completely eliminates understeer ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
In general, if you balance the car correctly with a smooth release of the brakes and transfer to power smoothly, the car will take a set nicely. Once the car is set and turn-in is complete, a hefty but smooth application of gas by/around apex is recommended to keep the car set. [This does not take into consideration trailbraking or trailing throttle to rotate the car.]
-td
-td
My (simple mind) reasoning is: contact patch is directly related to vehicle weight. You might have a wider contact patch with wider tires, but it will be the same area as a narrower tire, since you haven't changed the car's weight. With the same area in contact with the road, you will have the same traction. I.e., no reduction in understeer.
-td
Parts Specialist
I agree with you (himself) but what I read was increase throttle equals decreased understeer. I see where placement of the throttle is important and I supose with the *** coming slightly off track (sliding out) understeer can be achieved. The OP did not mention where understeer occurred, so in a sence the reply is correct and incorrect dependant on when in the turn it is used.
Thanks, fun info
Thanks, fun info
Ironman 140.6
Thanks, fun info
Thanks, fun info
