Two coats of Zaino on
#31
Ok, now that you have the car nice and shiny and clean, here is the
LA BuddaHead Waterless detail:
1. go over the car w/ a california car duster;
use the small interior duster to get the rims
2. Use Meguire's Quick Mist for any bugs, boogers, etc.
3. Hit the entire car w/ Meguire's Ultimate Quik Wax.
You can even go over the taillights, headlights with this product.
4. Use a Swiffer duster to get the interior.
5. Use a good liquid wax to get any stubborn dirt/dust off the rims.
6. Clean the windows
Do this once a week (should only take 30min). Use the duster daily as needed.
Your car will always look perfect and will never have to touch water.
#32
How do the Meguire's products mix with the Zaino? i.e. Do you do this waterless detail on top of other Meguire's products?
I was planning on keeping the outside clean with Z7 wash and Z6 gloss spray...
#34
You'd have to ask the PO - RocC4S on 6speed. I think if you search there, you may find some posts about it. I seem to recall that he had them sand blasted and painted instead of powder coated (something about heat affecting the rims) and that it cost ~$900.
#35
IMO a regular dry wash is better than wet washes.
You will find that the car will look better, and be easier to maintain.
You will know every inch of it.
#36
#37
Pretty good description of my Sunday ritual. If it doesn't come off with the duster and the Quik Wax, that's my signal to do a full wash... Not quite 30 minutes if everything is stored properly in the garage... One benefit of doing this once a week is that my wife isn't out there asking me why I'm rubbing the car again...
It's in the trunk, so I can touch it up whenever I get time. If I do it at work, then the wife doesn't get jealous.
#38
Great idea - only my trunk is fully cooperative. I'm not sure what combination of metaphysical forces needs to be in place for the latch to open, but it certainly doesn't open when I need it to sometimes... I do know that if I try, and it doesn't open, I can go away for some unspecified amount of time then it will open... I do know that it won't open if I need it to when I'm filling up with gas... or when I have the camera stored in there and I come upon the perfect backdrop... and I do know it will open when it has sat in the garage, again for that unspecified amount of time. But, right now figuring that out is a secondary priority...
#40
#41
Finally got around to hitting my tips with Mothers and doing most of the following. Got a bunch of grime off with the Quick Mist. The Mother's stuff worked ok, but I was only able to remove about half of the soot from inside the tip -- even with 0000 and 00 steel wool. Any suggestions?
#44
#45
