996 Forum 1999-2005
Help removing radio
Old 02-10-2009, 12:17 AM
salayc
salayc's Avatar
Originally Posted by sammy-r
Well 2 days later and I've gotten it to move a whole 1/4"!
You're almost there. The radio has released, it's just a pull away. You may find some funky work behind the radio once you remove it which is causing it to jamb.
FYI, generally you have to sacrifice a finger tip in order to get it out. It's how you can spot a true 996 DIYer.
Old 02-10-2009, 09:32 AM
perryinva
perryinva's Avatar
COOL PEN!!! I want one.....
Old 02-10-2009, 08:12 PM
sammy-r
sammy-r's Avatar
Finally got it out. It took one person pulling on the removal tools and another pulling from the cassette slot. It was tight at least 1/2 way out. No wires or anything pinched holding it in - just tight. The replacement CDR-220 is just as tight going back in so I didn't slide it all the way in yet. Now I'm having second thoughts about using it and thinking about going aftermarket.
Old 04-28-2012, 11:30 PM
barlowdo
barlowdo's Avatar
Interesting as my 220 radio is as tight as heck also. I must admit this is the first post on removing the radio that events of it being as difficult to pull out as I am experiencing.
Quick Reply: Help removing radio
