putting a pcar thru a auto carwash...
#33
As far as the coin-op brush, the place I go to has them hanging and before I use them, I spray them down w/ the high pressure wash cycle thoroughly to remove any heavy duty crap on them.
I use a California Water Blade to squeegie water off, then followup w/ a small towel, and, yep... it's not even microfiber.
///Michael
I'm not a fan of the waterblade either. I do use it on the canvas. For a well maintained car that's been clayed often..ok fine. But I generally avoid any friction when rubbing on the paint. I will sometimes spray a quick detailer on there before drying. But then again I plan to keep this roadster for 30 years.
#35
I am just a amateur detailer and it made cringe too!
It is sooo unnecessary to scratch a Porsche, and all you have to do is learn
a few do's and don'ts in here www.autopia.org
They have 3 on line "books" on line (free, top center homepage) that only take around 20 mihutes to read.
#36
Parts Specialist
Search Autopia for "Optimum No Rinse" or OEW. You need to be tedious with technique but it's an amazingly effective way of washing cars if done correctly.
All you need is two buckets of water, a small spray bottle (I prefer the pre-soak method), and several microfiber towels. I use this wash method for my own cars and customer cars in the cold winter months.
#42
I always hand wash. A quick tip for the colder months to not feeling so cold is wearing dish washing rubber gloves. It reduces how cold your hands feel as the water is not touching your skin and it will extend the amount of time you have before hands start to feel a bit numb.
Granted, I don't wash my car that frequently throughout the winter as it doesn't come out much but when it's needed the gloves make the task much more bearable.
Just, pick a good color for the gloves. Washing a car with pink gloves can open you up to a lot of jokes. LOL
My DD- Grand Cherokee on the other hand, gets the automatic car wash. It's my beater.
#44
actually you can do a waterless wash with only one bucket. Just use a grit guard at the bottome of the bucket and two ounces (shot glass) of Optimum No Rinse. Use a sheepskin mitt or a sea sponge, dunk and hold over the car to wet down. Wipe in the direction of the wind on each panel. Dunk the sponge or mitt after each pass. Use the remaining water in the bucket and a wheel face brush to clean off the wheels and tires.
Use a large waffle weave towel, fully opened, and slide it across each panel. Try not to rub back and forth or in circles.
I can do a pretty dirty car in less than 10 minutes with one of those orange Home Depot buckets. I follow up with FK1 #425 spray polymer on paint, glass, wheels and interior. It acts as teflon barrier of sorts that significant cuts down on future cleanings. I have a hose but I only use it to wash out the wheel wells and deep rinising of the canvas.
#45
