EVO CAI installed - What do I do w/ Breather Line??
Guys, I just installed a Fabspeed intake with the red tube on my Tip C2. I also have this breather line that I do not know what do do with. As shown by Christian above, it appears that Evo and K&N have Tiptronic solutions for this extra line. Fabspeed does not. I called them and they said that I could do one of the following:
1) Put a breather tube filter on it (as suggested by Arnee). If I go this route, can somebody help recommend what/where to buy?
2) Drill a hole and put a grommet in the Fabspeed tube and tap the line into the red tube. I prefer this solution as this would be equivalent to the Evo solution above but I have no idea which parts to buy, how big a hole to drill, etc. etc. If somebody can give me some suggestions, I'd really appreciate it.
Thanks in advance!
Thanks in advance!
John,
Maybe some of the other guys can be more specific, but basically you need a plastic nipple similar to the one on the breather tube. Punch that thru the silicone tube and secure it. Then get a small length of vacuum hose and connect the 2. I would think most of these things could be found at Kragen.
Good luck.
Good luck.
I brought both the OEM hose and Fabspeed red hose to Kraegen Auto today and told them what I wanted to do and they were no help at all so I'm asking the experts here.
John,
Good luck.
Good luck.
Use the terminology of "vacuum hose couplings"
Will be plastic looking, or nylon, or poly.
Looks like this:
![](http://www.mcmaster.com/param/images/barbedhf/5218k65l.gif)
or this
![](http://www.mcmaster.com/param/images/barbedhf/Adapterhp.gif)
Found HERE
Just match the ID of the breather tube to the OD of the barb. I'd use a little sealant, maybe silicone, on the intake side to assure a good seal and prevent leaks.
My local Autozone has all kinds of these, or try like you said any local hardware store.
HTH
Looks like this:
or this
Found HERE
HTH
Went ot Autozone today and bought a pre-molded rubber hose that included a 45 degree bend. The hose has a 3/8" inner diameter to accommodate the factory vacumn line. I cut the hose and left about 1-1/2 inches on both sides of the bend to form an elbow connector, then drilled a 1/2" hole in the red Fabspeed tube. I plugged one end of the elbow connector into the hole in the red tube, sealed the connection from the outside with some silicon adhesive and plugged the vacumn line into the other end of the elbow connector. Attached photo shows the finished result. I hope the solution holds up.
Thanks to those who offered helpful advice and made me brave enough to attempt this DIY effort.
John,
It looks pretty good. I would watch it over time and make sure it doesn't vibrate loose. If it does I would go with a plug connector like Anderson suggested.
Quite frankly, for what you payed for it, it kind of annoys me that Fabspeed doesn't take a more active role in finding a solution for you, but that's another story.
John,
Yes, I would have preferred to build something more solid like Anderson suggested but Autozone didn't have the right parts so I ended up with what I had.
In fact, I would've preferred not to tinker with these homemade solutions at all. If Fabspeed would just sell me a kit to do this minor mod, I would've gladly overpaid just to know that I got something true and tested.
Anderson put a link in his post so you can order the part online. My concern is that the silicone could break loose over time and get sucked into the engine.
Newbies Hospitality Director
John,
