Blown Head Gasket repair costs
sounds familiar. I suggest getting the Porsche replacement engine. GL
https://rennlist.com/forums/996-foru...e-failure.html
996 engien failure
Hey guys, I have the same kind of problem. I am eating coolant as welll. And i dont know where it goes. I took it to porsche and they said there is moisture/coolant in cylinder one. The engine light flashes on startup and stays on after that. There is no oil in the coolant tank, but i think there is coolant in the oil because i drained the oil and it was very thick and black. Any ideas what the problem could be? i was thinking cracked head or blow head gasket. Any pointers would be great... thanks!
2001 c4 tip.
2001 c4 tip.
Former Vendor
https://rennlist.com/forums/996-foru...der-liner.html
See this thread. the same pertains to your situation. These engines simply do not blow head gaskets, they have all the symptoms of a blown gasket to those that lack the direct experience with the M96 to know they simply do not fail. The head gaskets are the most effective part of these engines.
