996 Forum 1999-2005
M96 Engine failure teardown this weekend
Old Jan 17, 2009 | 10:19 PM
  #31
easyC's Avatar
easyC
Originally Posted by Ray S
Is the 2001 3.2 a variocam plus or regular variocam motor?
Was there excessive wear on/around the chain ramps for the variocam?
Thanks again.
regular variocam... 7.2... now car is 7.8 with variocam plus
yes there was excessive wear on the chain ramps for the variocam... as per our master mech there...
Old Jan 17, 2009 | 10:29 PM
  #32
cdodkin's Avatar
cdodkin
Good luck with that assumption. The "all M96 engines are bad" crowd is already circling.
Thanks for the post and the high quality images. Is the 2001 3.2 a variocam plus or regular variocam motor?
Thanks again.
Ray, the only person who even mentioned "all M96 engines are bad" is you!
Get over it.
Old Jan 17, 2009 | 10:47 PM
  #33
cdodkin's Avatar
cdodkin
Originally Posted by easyC
looks like cylinder 4 hydrolocked from a cylinder crack...
So what's the prognosis - does it look like the constant flexing of the block caused a structural failure in the cylinder wall?
Or did the block crack and take the cylinder with it?
Old Jan 17, 2009 | 11:11 PM
  #34
ivangene's Avatar
ivangene
Parts Specialist
Wow, thanks for the photo's - I took quite a bit of time looking at each one....
Old Jan 17, 2009 | 11:34 PM
  #35
easyC's Avatar
easyC
the prelimenary diagnosis is a cylinder wall crack... I may be sending this to Raby for an in depth diagnosis though now...
Old Jan 17, 2009 | 11:37 PM
  #36
cdodkin's Avatar
cdodkin
Interesting that it was cylinder 4.
It's more common to find one of the center cylinders cracking.
That's why I was asking if the head had cracked as well, as this is more common on the outer cylinders.
Did you have any signs of intermix or coolant loss before the engine eventually let go at the track?
Old Jan 17, 2009 | 11:51 PM
  #37
easyC's Avatar
easyC
well none of those signs were seen... it was a friday open lapping day, fairly cool, and on my first hard lap of the day after two warm up laps... coolant and oil were checked that morning as well... also you can see the heads in the photo... the piston themselves were completely destroyed and only a few larger pieces were left as can be seen in the first photo from inside the cylinder... my theory is that the crack in the wall reached its critical point that morning on the track, and trying to start it multiple times later caused the hydrolock... again this is just my amateur theory... Im medically trained... not mechanically...
Old Jan 17, 2009 | 11:55 PM
  #38
redridge's Avatar
redridge
Thanks for sharing... If you find out more from the experts... we would appreciate the updates.
Old Jan 17, 2009 | 11:57 PM
  #39
Van's Avatar
Van
Originally Posted by Macster
One can even elect to take engine up to 4.0l. All it takes is money.
Do not recall off hand if any company in USA offers this.
If anyone does, I bet it's these guys: http://www.lnengineering.com/
Old Jan 18, 2009 | 12:25 AM
  #40
Jake Raby's Avatar
Jake Raby
We are working with LN now on a 4.0 engine based from a 3.2 foundation with our parts and processes coupled to theirs.. I have done all the product testing and development for LN and was their very first customer years ago... We work together continually.
Lots of things never seen or heard of before will be released really soon. We have been busy!
Like I said on 986 forum, these broken pieces are valuable to our program and I'll purchase them for investigation.
I'd have to see it up close and Charles would have the final call in the matter, but I'd say that this block is repairable with LN's procedures. It would be a good foundation for one of our 4.0 test engines.
Old Jan 18, 2009 | 12:58 AM
  #41
b-man's Avatar
b-man
Thanks for sharing the pictures.
b-man
Old Jan 18, 2009 | 01:31 AM
  #42
Ray S's Avatar
Ray S
Ironman 140.6
Get over it.
That didn't take long, cdodkin the resident engine e-thug has arrived....
Old Jan 18, 2009 | 01:32 AM
  #43
Ray S's Avatar
Ray S
Ironman 140.6
Thanks for the info.
Old Jan 18, 2009 | 01:34 AM
  #44
cdodkin's Avatar
cdodkin
your attempts at personal attacks are not welcome in this thread, or on this forum.
Give it a rest.
Old Jan 18, 2009 | 10:42 AM
  #45
judd944's Avatar
judd944
Wow, it looks worse in person. Great photos !
