996 Forum 1999-2005
battery problems....?trickle charger??
Old 01-24-2009, 08:12 PM
  #31
dertub
dertub's Avatar
I have 3 of these problems. The 2 collectors stay on a Porsche trickle charger always when not in use. I run the wire under the door anywhere and close it. There is no problem starting them. The 3rd "driver" gets started up enough that it's not a problem. I have replaced the battery twice over the years with a Sears battery and my own labor. If you have an ignition switch problem, you may very easily run a battery down in a few days by letting it sit. I had this problem and destroyed a battery. I also recommend a Sears charger with variable settings to bail you out when your battery is low, but not dead.
Quick Reply: battery problems....?trickle charger??
