996 Forum 1999-2005
Automatic spoiler extension question
Old 01-09-2009 | 01:46 PM
  #31
medtech's Avatar
medtech
How does Porshe change the setting between US and German versions? A resistor?
Old 01-09-2009 | 02:45 PM
  #32
Edgy01's Avatar
Edgy01
Poseur
Originally Posted by medtech
How does Porsche change the setting between US and German versions? A resistor?
There should be no difference between a US model and a Euro model when it comes to deployment speeds.
My 997 one goes up at a real 75 mph (indicated 77.8 mph). I use a smooth sided black truck to confirm the spoiler position!
Old 01-09-2009 | 02:57 PM
  #33
himself's Avatar
himself
Originally Posted by kas930
I've got a '99 C2 Cabriolet and as a Christmas present to myself I recently installed a dash mounted indicator light that flashes as the rear spoiler is either being extended or retracted, and stays on solid when the spoiler is fully extended. Since doing this I've learned that the spoiler extends at 50 mph and retracts at 25mph. I'd like to change these number to something a little higher (like extend at 75 mph and retract at 50), anybody know if this is possible?
Keith
Wow. Sounds like your speedo is way off
-td
Old 01-09-2009 | 03:30 PM
  #34
medtech's Avatar
medtech
I don't think that is true. I had read that German version is set at a higher speed. In the US they had to lower it to 75MPH, otherwise the wing would never come up.
Old 01-09-2009 | 03:43 PM
  #35
1999Porsche911's Avatar
1999Porsche911
I run the European DME and it is the same.
Old 01-09-2009 | 03:47 PM
  #36
medtech's Avatar
medtech
Good to know. Thanks.
Old 01-09-2009 | 04:05 PM
  #37
Gary's Avatar
Gary
Originally Posted by Dave!
Yep, it will lock it in the raised position until you manually lower it. Pretty easy to tell if someone's been having fun when you see their parked 911's spoiler raised.
A perhaps noob like question - As per another thread, I'll be going to see a couple of C4S's next week and the week after - I've just had some high res photo's sent of the inside of one of them - but do not see any switch to manually raise / lower the spoiler? Where is it (or, is it an option which apparently I won't have?)...
Regards,
Gary.
Old 01-09-2009 | 04:24 PM
  #38
Couper's Avatar
Couper
It's down by your ankle on the fuse panel.
Some ppl add a switch on the dash. It's not difficult or expensive.
Old 01-09-2009 | 04:56 PM
  #39
Gary's Avatar
Gary
Thanks, appreciate it That's another box ticked and out of the way!
Gary.
Old 01-09-2009 | 06:09 PM
  #40
porschedog's Avatar
porschedog
I've ordered this but have not yet opened the box. How much of a pain was the install?
Old 01-09-2009 | 08:29 PM
  #41
kas930's Avatar
kas930
It's not that bad at all to install. The only problem that I had was that the wire colors specified in instruction for the extending and retracting signals did not match what my car actually had. It would have been helpful if the instruction referenced the pin #'s of each connector. I have the full manual so I figured it out from the wiring diagrams. If your familiar with how the instrument cluster is removed, I'd say that you can do the entire install in about 30 minutes.
Old 01-10-2009 | 12:54 AM
  #42
wross996tt's Avatar
wross996tt
Or, you turn off and restart the engine.
Not on my car...if I raise it manually, just restarting the car does not lower the spoiler. Found this out after washing the car with the spoiler up.
Old 01-10-2009 | 08:36 AM
  #43
LVDell's Avatar
LVDell
You have to break the 75mph again for that to happen. Just turning off and then on the car doesn't do it.
Old 01-10-2009 | 08:48 AM
  #44
gota911's Avatar
gota911
Newbies Hospitality Director
Statman, if you didn't use "Mobile water" in your car, I am sure your spoiler would also retract after the next restart!
Old 01-10-2009 | 08:52 AM
  #45
LVDell's Avatar
LVDell
Quick Reply: Automatic spoiler extension question
