996 Forum 1999-2005
Automatic spoiler extension question
Old 01-08-2009, 11:23 AM
Dave!
Dave!'s Avatar
Sad face is right. Looks like you guys miss out on having the wife wave at the spoiler and say "Hello!"
Old 01-08-2009, 11:31 AM
92tsiawd
92tsiawd's Avatar
I have a newb question, what happens if you are on the track, go 75 mph + down the straights and in some tight corners go slower than 37 mph? Does the wing just go up and down while you are on the track? Is there any way to keep the wing up? Maybe press the button to get the wing up and pull the fuse?
Old 01-08-2009, 11:33 AM
gota911
Newbies Hospitality Director
gota911's Avatar
IIRC, it you extend the spoiler manually (with the switch), it will stay extended until you retract it manually.
Old 01-08-2009, 11:42 AM
Dave!
Dave!'s Avatar
Yep, it will lock it in the raised position until you manually lower it. Pretty easy to tell if someone's been having fun when you see their parked 911's spoiler raised.
Old 01-08-2009, 12:06 PM
1999Porsche911
1999Porsche911's Avatar
Or, you turn off and restart the engine.
Old 01-08-2009, 08:54 PM
kas930
kas930's Avatar
I had someone follow me today and I can now verify that my spoiler is indeed extending at 50 mph and lowering at 25 mph, so the LED is telling the truth.
So, back to my original question: Does anyone know if these values can be changed?
The only thing that I can think of that could have caused my speeds to not be correct is that I replaced the instrument cluster with a brandnew one (I had an Indy reprogram the cluster with the correct mileage and features). Not sure if this could have something to do with it.
Old 01-08-2009, 09:06 PM
Mathemagician
Mathemagician's Avatar
Thanks for the tips! I may well give it a go. It's a wonder nobody has thought to put the indicator light right on the spoiler switch. That would seem to make a lot of sense, no?
Old 01-09-2009, 09:01 AM
DFC
DFC's Avatar
I know that it is not user configurable, but I am not sure if someone with a PST2 or PIWIS has the ability to change the values in the cpu directly. Might want to ask on Renntech.org, Loren is familiar with this equipment and may be a better source.
Old 01-09-2009, 09:14 AM
LVDell
LVDell's Avatar
Very odd that it rasies and lowers at those speeds. Almost sounds like an incorrect DME in the car? Not sure if that is even possible.
Old 01-09-2009, 09:37 AM
Couper
Couper's Avatar
I'm pretty sure It's not programmable even with Porsche tools.
A lot of ppl ask about lowering the speed at which it raises so they can
look cool on the highway without breaking the speed limit. I've never heard of
a solution other than moving the manual switch to the dash.
I'm wondering if your light kit didn't have something to do with the speed change.
Where'd you get it?
How's it wired?
Old 01-09-2009, 09:52 AM
Couper
Couper's Avatar
Sorry, I just reread the thread.
I don't remember what the speed signal pin is but if your kit tied into that, then
I'd guess it's 'manually' raising and lowering the spoiler at those speeds and overriding
the factory speeds.
Why else would an indicator light need to know how fast you're going?
Old 01-09-2009, 10:43 AM
1999Porsche911
I have no idea what wire you used to read the speed signal, but I always use a direct feed from PIN 80 of the DME. Obviously the siinal you are getting from the wire you are reading reaches a level need to activate the spoiler relay. Easy solution is to install a resistor on the wire which will not allow the spoiler to open until a higher speed.
Old 01-09-2009, 10:51 AM
redridge
redridge's Avatar
this guy did it and he's been selling this for awhile... its a good idea for troubleshooting purpose...
http://cgi.ebay.com/ebaymotors/Spoil...QQcmdZViewItem
Old 01-09-2009, 11:40 AM
kas930
kas930's Avatar
That's the exact kit that I bought... and the connections are tied to the movement of the spoiler (extend, retract and extended signals) not the speed signal. I'll see if I can find out the answer over on the renntech site and let everyone know what I find out.
Keith
Old 01-09-2009, 01:25 PM
Mathemagician
Sweet, thanks!
Quick Reply: Automatic spoiler extension question
