A $600 Oil Change
#46
Yup, that's what I was afraid of! I got the front end way off the ground - almost to the limit of the jack and it still wasn't high enough to get the stands under the rear. I figured no good could come of going further and very slowly lowered the car for fear if it slipping.
I have to find some good ramps at some point.
I use rhino ramps and love them, unfortunately mine werent around at the time........
#47
The Penguin King
This thread is starting to be a back and forth issue but I only started the thread to bring up the point that the engine lift, while it might be acceptable, it isn't a Porsche approved procedure. Because its not always easy to find what is or isn't real a Porsche procedure I wanted it to be known. It is my opinion that if jacking the using the engine mount causes enough stress to burst a mount, whether used or not, it isnt one to be used regularly. As for me, I'm in the process of building ramps that raise the rear-wheels about 1-1.25 feet off the ground with a shallow angle appropriate for my ground clearance. That being said, anybody that doesnt follow the mainentce or repair schedules to the tee at Porsche certified locations is, according to Porsche, a "shade-tree mechanic". I do my own mainentence and repair to the extent I can and have no problem straying from Porsche recommendations assuming that it is well founded. I just dont think this is a well justified exception, from what I could tell, jacking from the engine wasn't necessary the safest or the least stressful on the car. Furthermore, I doubt that jacking from the single point on the back of the engine replicates even closely the force load that is applied to mounts under normal driving because all the force is located on the rear engine mounts and not on the additional transmission mounts.
#50
Hey, I resemble that comment in bold.
#51
I make it a habit of staying out of such threads but I will chime in and say that when we raced my 996 we only used the engine jacking point when no other approach would work and then we did it very carefully.
To put our car on jackstands we used the rear jacking point and put one jackstand under the front jacking point and the other (with the cradle removed) over the bolt head near that rear jack point that holds the black brace that runs at a 45 degree angle from there to the cross member. It's hard to describe from memory and without pictures but it should be pretty obvious. This method was much faster and much much safer than putting the front on stands and using the engine to lift the rear.
Just my 2 cents worth. I'm probably wrong.
Jim
Jim
#52
#53
Well, thanks to the OP Navy for posting your experience.
I have a different technique for lifting the rear of my '62 Bug, but certainly have jacked the 996 this way to set up jackstands when changing out exhaust a couple times.
(I don't like ramps myself.)
Just good to be aware of this, and also to take a look at the mounts once in a while.
#56
Looks like we have two distinct camps here....those who jack their cars up using the engine point, and those who feel that this is tantamount to heresy. I think Orient's intent was to provide us with an alternative to jacking up the car. Doing it this way takes both rear wheels off the ground at the same time and facilitates the insertion of the jack stands. Those who feel this contributes to engine mount failure may have a valid point....but I know of many professionals who use the engine jack procedure. Actually more guys I know use this procedure than those who don't.
I guess if you want to use the technique....go ahead and do so....if the thought of doing it this way raises your anxiety level....go the other route. I've been using Orient's method for some time now and have never had a problem. If I blow a mount....I'll fix it. This is almost becoming a Shakespearean.....Much Ado About Nothing.
#57
Newbies Hospitality Director
Well, at least about the "uncouth" part anyway!
