996 Forum 1999-2005
Swapped pads - my thoughts
Old 08-18-2008 | 12:17 PM
befast's Avatar
befast
Smile Swapped pads - my thoughts
- Pad change itself is possibly even easier than an oil change
- When did the putty knife become a main tool in the chest?
- Newfound respect for pit crew wheel changers. Mine are only 10", but fully inflated are something else to toss around.
- Nothing quite has the same ring as saying: I busted the rubber (gloves), while jacking the car, and I still have to bed the pads.
I didnt use the vibration dampers, and because I used Hawk HPS, I tied back the sensors. No squeels from anywhere, *yet*. The way the vibration dampers fit into the pistons, they seem like an integral part of the setup. Is it really ok (mechanically) to be without them? Also, the pin/spring kit seems relatively unbreakable, why bother replacing it? How do I know the pads have been well-bedded? I've noticed that my driving style for everyday uses little braking.
-- befast
Old 08-18-2008 | 01:22 PM
insite's Avatar
insite
just drive normally; no need to bed these like race pads. the surfaces will mate naturally over a couple hundred miles.
you're fine without the vibration shims; i promise.
i never saw the need to replace the pins either. if the pads actually slid on the pins, i'd feel differently, but they really don't contact one another. i re-use mine.
Quick Reply: Swapped pads - my thoughts
