996 Forum 1999-2005
Got weighed today?
Old Aug 13, 2008 | 03:40 PM
Orient Express's Avatar
Orient Express
Default Got weighed today?
I have always wondered what the Orient Express weighs, so I found a truck scale and weighed the car. An 02 996 C2 cab, I had a full tank of gas and myself on the scale, and it came out to 3580 lbs., 1440 lbs. on the front wheels and 2140 lbs on the rear wheels. 40/60.
Now that I have the weight of the car, I can download the "must have" application for my iPhone. or only $13 you can download the Dynolicious G-meter software for your iPhone or iTouch.
If you have 7 minutes, Click here for a live review and test comparing Dynolicious to the G-Tech Pro, and an actual dyno and drag stip test.
Gotta have it!
Old Aug 13, 2008 | 03:44 PM
Ahmet's Avatar
Ahmet
May I ask how much you weigh? Any extra accessories or anything removed from the car?
Old Aug 13, 2008 | 03:49 PM
David A's Avatar
David A
That's a very cool thing to do. I want to do mine.
Old Aug 13, 2008 | 03:58 PM
Tippy's Avatar
Tippy
I like the 25% drivetrain loss on the cooper. Open mouth and insert crack pipe.
I believed my Tip weighed 3250?
Old Aug 13, 2008 | 05:07 PM
Orient Express
Subract about 185 for me, but the car is pretty much stock, as delivered.
I wonder what the other variations of the 996 weigh?
Coupe, 4S, GT3, GT2, Turbo Coupe, Turbo Cab, Targa? Anyone got the weights of these cars? I bet I am one of the heaviest cars.
Old Aug 13, 2008 | 05:22 PM
Barn996's Avatar
Barn996
So 3395lbs with no driver and a full tank...how much does gas weigh?
Old Aug 13, 2008 | 05:26 PM
wross996tt's Avatar
wross996tt
My turbo cab...full tank, no occupants...3580.
Old Aug 13, 2008 | 06:04 PM
4ng crcs's Avatar
4ng crcs
6GT3 w/half cage, euro gt3 seats, 1/2 tank no driver=3224.
On the other hand, the RS6 is 4302 with 1/2 tank no driver. And since its the anti-911 with the motor out front of the front axle line it likes to push it's way through the corners.
Old Aug 13, 2008 | 07:39 PM
Orient Express
Default A gallon of Gas weighs:
At 60 degrees Fahrenheit, a gallon of gasoline weighs about 6.15 pounds. So if the fuel tank has a capacity of 16.9 gallons (inc. reserve), or 104 lbs.
The dry weight of my 996 Cabriolet is 3291 lbs.
Old Aug 14, 2008 | 12:35 AM
jumper5836's Avatar
jumper5836
996 C2 mkI 2,919 lbs
996 C2 Cab mkI 3,096 lbs
996 C4 mkI 3,032 lbs
996 C4 Cab mkI 3,209 lbs
996 GT3 mkI 2,976 lbs
996 Targa 3,175 lbs
996 C2 3,020 lbs
996 C2 Cab 3,197 lbs
996 C4 3,152 lbs
996 C4 Cab 3,329 lbs
996 C4S 3,296 lbs
996 Turbo 3,394 lbs
996 Turbo Cab 3,660 lbs
996 GT3 mkII 3,042 lbs
996 GT2 3,153 lbs
Old Aug 14, 2008 | 11:26 AM
wross996tt's Avatar
wross996tt
Originally Posted by jumper5836
996 C2(98) 2,919 lbs
996 C2 Cab(98) 3,096 lbs
996 C4(99) 3,032 lbs
996 C4 Cab(99) 3,209 lbs
996 Targa 3,175 lbs
996 C2(02) 3,020 lbs
996 C4 3,152 lbs
996 C4S 3,296 lbs
996 Turbo 3,394 lbs
996 Turbo Cab 3,549 lbs
Where are these from?
Factory data for 996 Turbo cab is 1660 kg / 3660 lbs
I have weight reduced mine somewhat.
Old Aug 14, 2008 | 06:58 PM
htny's Avatar
htny
The owners manual has dry weights for all the variants for that particular year (not GT3 or GT2) for tip and standard in the back, but specifies a range (qualified as depending on equipment, e.g. satnav, bose stereo, full leather, wood, etc.)
Old Aug 14, 2008 | 08:16 PM
Tbred911's Avatar
Tbred911
my car weighed in @ 3,040 lbs
... I had half a tank of gas in the car... driver's side EURO GT3 seat... full leather and sunroof... spare tire and some other stuff was in the front hood... not much though...
*I was not in the car when it was weighed*
car is a 99 C2
Old Aug 14, 2008 | 10:20 PM
ivangene's Avatar
ivangene
Parts Specialist
Well crap, I just found out about the G-Force and was thinking about getting one... THANKS to your youtube video I think I will consider something else (iphone / ipod program)
Thanks for the post, very interesting
Ed
Old Aug 14, 2008 | 10:55 PM
ivangene's Avatar
ivangene
Parts Specialist
I just spent some time searching this out, many of the user reviews had the same point... crashes and wont load car specs (which is required forHP measurments) It is supposed to load on iphone or ipod touch. The info I have says its great, but needs refining to be all it says it is, still for $13 (vs $100-$300 for G-force) it might give you enough to decide if you need more or can live with this much...
Something tells me after a few 100 times of running, many will grow tired of it and not use it, so the money saved is well worth the money spent...
Now back to you Ted
Errr .... Ed I meant
