Removing coupe rear window seal
Anyone done this? Do you have to take the rear window out to replace the seal? I'm pretty sure on the front window the seal can be replaced (at least the rubber trim) without removing the window....
Thanks in advance,
Paul.
Thanks in advance,
Paul.
According to the manual procedure for replacing the rear window (which incidentally is bonded in place just like the windshield), you simply pull the trim out from around the window.
