CEL---- o2 sensors
Guys, my car is at the stealership for a 30k service. On the way over there, the CEL came on, no problem I thought, I am going to the service center... Anyway, the reading shows a bad o2 sensor, but they cannot repair/replace or confirm the error because I have a custom exhaust... headers, high flow cats, mufflers.
They recommend replacing all parts to OEM and run it stock to get rid of the code. I recommended they check in to the local psych ward. Since they cannot guarantee any results, my dilema is, should I just pay them to replace the o2s and risk the light coming back on? Should I shell out the money to replace the cats that they think are bad and replace o2s?
I don't want to restrict my system, as it is full exhaust, intake, and programmed. I also don't want to spend 3k dollars for a meaningless CEL. Otherwise, I can clear it myself and ignore it for as long as possible, but what is the downfall of running with bad o2 sensors.
I need to pick it up tomorrow or I need to tell them to repair it, i will be trying the other boards as well.
It is much cheaper to replace the sensor. Buy it yourself at suncoast and install it yourself. To clear the code you will have to disconnect the battery. Just remember that you will need your radio code. If the dealership is planning on replacing the MAF sensor anyways, it might be worth giving it a try.
Thank you for the quick response.
Well, the crooks charged me 130 dollars to diagnose the engine code... which they failed to mention when I dropped it off. This can be applied towards the repair if I have them do any sort of repair, so I was thinking to just change them anyway since I had 140 dollars worth free.
No, running rich or lean I would be OK with.
He said it is indicating "failing sensor" which leads me to believe I should replace them. BUT, he said doing so is worthless without reverting the exhaust to stock form, which is not an option.
First please tell us what the car is. Second, get the actual code (since you were ripped off $140 for it it is yours). Post the numbers here so we have a better idea. The guy sounds like an idiot as plenty of O2 sensors work with aftermarket exhaust. It could be as simple as it came unplugged or was plugged in wrong....post the codes please.
Nice car! How many miles?
One question. How long ago did you upgrade the exhaust? 1st thought that comes to my mind is if it's run with that exhaust system for a good while, then it has nothing to do with the o2 sensor failure. 02 sensor's do go bad after a while (100,000+ miles).
Sounds like this guys making you diagnose the car so he won't be responsible if his repair doesn't work. I'd say take the car somewhere else and call it a $140 lesson (pretty cheap lesson in the Porsche world).
Did I say that's a NICE car??
From time to time I do have a CEL too (code 1276); it started with the aftermarket headers that I put on my '00 C2 (42k miles); aftermarket exhaust alone didn't trigger CEL. Last time it popped up, I just checked the code with my OBD II reader and erased it. However, the time before I had this code I cleaned my MAF (I had the same code together with a MAF related code when my MAF went bad after the K&N CAI install). However, it can be that there's an air leak somewhere in the exhaust system that triggers this CEL which I'll check when I've my car on a lift next time. If there's no leak and the CEL comes back, I plan to change the O2 sensor. Car runs great and it doesn't harm the engine even if the O2 sensor would be bad.
Unless I'm crazy the exhaust itself would have to be awful for it to throw enough grime back to the O2 sensors to cause problems. headers miiight be able to cause problems, but before you go paying people money for labor, ask your dealer if you can apply the 140 bucks you owe them to new sensors from the parts department. Then crawl under, inspect, replace yourself and reset. That's what I'd do
You could try clearing the code and waiting to see if it comes back.
Thanks for all the great responses guys. The car has 40k miles on it. Since the fluids looked especially dirty and I do not know the full history of the car, I had them do the 30 service. The exhaust system is suspected to have been on since 99. I didn't install it. The car was owned by a porsche service manager for the first 20k miles, so I would imagine things SHOULD have been done correctly.
If they allow me to do it, I will be applying the diagnostic fee to the parts and leaving with them as suggested. I will not be back to the dealership after this service. They gave me just enough bad taste to lose my business. Which blows my mind because with the economy the way it is and the ability to use internet for car shopping, it seems like dealerships would be treating customers like kings to keep them happy.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
my cel went on the other day without anything unusual in the engine bay. i figured o2 sensor or maf since i had the evo intake installed last year. also, i tightened the gas cap. i cleared it by disconnecting the battery, will watch it closely before i go to the dealer, i'd go to autozone first if it comes back on.
