996 Forum 1999-2005
Coolant Leak - Where does this hose run?
Old 09-05-2008, 04:18 PM
racer08
racer08's Avatar
PN is 996-106-226-52 for anyone who needs this in the future. Took about 20min to change being really careful not to break the new one.
Old 01-13-2015, 07:41 PM
upthesharks
upthesharks's Avatar
Hi, how do i remove the single use clamps?
I have seen people upgrade to metal connectors such as Edelmann 750400 and the one i am going for is Husky Brass connector from Home Depot ... Model # HDA40700AV
Old 01-13-2015, 08:08 PM
996pp
996pp's Avatar
I would just take some cutters and clip the head off, that should loosen it enough for it to slide out.
Old 01-13-2015, 08:45 PM
Ahsai
Ahsai's Avatar
Or use a screwdriver to pry the ear of the clamp and spread it a bit. Once spread, the clamp will lose its tension and will be easy to remove. The stainless steel clamp can be difficult to cut.
Old 01-21-2015, 02:49 PM
upthesharks
Thanks guys. I used some cutters to lop the top off and then peeled off the top layer and slid the bottom layer off. I'm using screw clamps at the moment but I had the original single clamps delivered from Porsche. Now the reverse question, how do I clamp it on? I might stop by dealer and ask them.
Old 01-21-2015, 04:24 PM
Ahsai
Ahsai's Avatar
The proper tool is this one
Amazon.com: Oetiker Style Hose Clamp pliers (pincers) with side jaw: Automotive Amazon.com: Oetiker Style Hose Clamp pliers (pincers) with side jaw: Automotive
You can probably get away using something similar.
Old 01-21-2015, 05:46 PM
dporto
dporto's Avatar
Received 1,165 Likes on 795 Posts
Originally Posted by Ahsai
You can usually get oetiker clamps and hose end pliers at plumbing/irrigation supply houses...
You can usually get oeticker
Quick Reply: Coolant Leak - Where does this hose run?
