Wevo Motor mounts
Wevo Motor mounts
My motor mounts are shot and need to be replaced. I inspected them and one is really sloppy and the other is nowhere near acceptable.
Anyhow I've spent over an hour searching threads today on the Wevo mounts and they seem like the way to go as far as upgrading the mounts. However I can't get much feedback on the standard Blue pillows for the mounts vs. the Black pillows. I'm leaning towards Black just for the fact that my car still spends much of it's time on the street. However Several of the GT3 guys are using the standard blue mounts and state they have no discernable increase in cabin vibrations with these mounts.
I was hoping that Wevo would be able to give me feedback on vibrations vs. the OEM RS mounts or Hard rubber mounts but they wrote back and stated they had no comparison data.
Anyow...if anyone has these mounts and simply hasn't posted about them I'd love to hear your impressions.
http://www.wevo.com/Products/Chassis...gineMounts.htm
Andy
Andy
Andy, do you track the car considerably? I do, and still run with the stock mounts and there is NO detriment from running the stock mounts. Contrary to what most will say here, there is not the significant weight shift from using a non-solid mount like the stock ones.
Dell,
I agree, BUT somehow with only 45K miles on my car the mounts are shot and the Wevo product seems to be standing up to the abuse given to it by track cars. Also it's cheaper than the OEM mounts so I figured why not. An added benefit is that if they do wear out the pillows can be replaced for $35 vs. another set of OEM mounts at $300-400.
Andy
Andy
Andy, now that is one rational answer!
If you have to change your mounts then maybe go with the WEVO product. The only caveat is that they do NOT make a 996 mount and will tell you as such. What I find comical is that if you contact them they will say they do not approve them for the 996 yet their website says to use the 993 mounts with a longer bolt.
Andy,
Have you considered RS mount. My mounts were shot and I changed to RS mounts last month, and felt immediate improvement on shifting. And also deeper sound from the engine. I ordered from Sunset for around $330, but you will have to source a longer center bolt. If you need part #, let me know.
OEM mounts are $260/pair, RS mount definitely a cheap/good upgrade.
M
M
The improvement you felt was replacing shot mounts, not upgrading to the RS mounts. You would have felt the exact same thing with the stock mounts. Not sure I follow your "deeper sound" comment. Do the RS mounts have some sort of noise maker attached to them?
Andy,
M
M
They should be here on Tuesday...I'll report back after the install. Anything's better than my compressed / leaky stock mounts that are in there now.
Andy
Do you have the specs on the longer bolts required for the installation of the Wevo mounts?
M12 x 130mm.
Not sure on the thread pitch so I'm going to buy bolts as well as nuts to make sure I've got the proper thread pitch and everything in place when the mounts get here.
Andy
Andy
If you were referring to the knock sensor, I am sure the frequency is different and probably not cause a false reading but there will be more vibration send through the reciprocating parts, that is fact.
I have had solid motor mounts on cars twice, just making sure people don't use them on their 996. Not fun to feel the vibes of the motor everyday.
