How do I tell if my turbo-twists are "hollow"?
OK, car is an '02 C4S with what I believe are stock turbo-twist wheels, but I'm not the orignal owner so can't be sure. So anyway I'm replacing the rear pads today and got to looking at the wheels from the back. The spokes have deep grooves in the back, presumably to reduce the wieght.
Does this mean they're the "hollow" spoke wheels?
Lifetime Member
Lifetime Member
Two ways to tell, (1) Metal valve stem = hollow spoke, rubber = solid (2). Grab the spokes, if you feel ribs in the back of the spokes then it is solid, if feel smooth then it is hollow spoke.
996tt mostly use hollows... however the 996gt2 use solids.... they are stronger and heavier! In NY/NJ area winter is def harsher than driving in the summer.
The 2001 996 TT came with solids.
Factory 996 Turbo Hollows
8x18" at 22 lbs 2oz
11x18" at 26 lbs 5 oz
Factory 996 Turbo Solids
8x18" at 26 lbs 2 oz
11x18" at 31 lbs 6 oz
Factory 996 GT2 wheels (earlier years, Turbo Solids):
8.5x18" at 28lbs 11 oz
12x18" at 33 lbs 0 oz
Factory 996 GT2 wheels (later years, GT3 style)
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
and for some comparison
Factory 996 GT3 wheels
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
Factory Carrera S 997
8.0 x 19 - 22 lbs. 4 oz.
11.0 x 19 - 27 lbs. 12 oz.
8x18" at 22 lbs 2oz
8.5x18" 25 lbs 2 oz
12x18" 29 lbs 0 oz
8x18" 22 lbs 10 oz
11x18" 27 lbs 11 oz
