Control arm movement?
Need a little help from the techs... Firstly '02 C2 NB.
I've been hearing a clunk from the rear... I investigated and the control arm looked like it had been moving around as there was a part of the sub frame where the control arm attaches to that is highly polished. Surely this shouldn't be moving? Right?
Take a look: http://picasaweb.google.com/karlgrov...32199736620402
Thanks in advance,
Karl.
Thanks in advance,
Karl.
No, the camber eccentric should not be moving in the sub frame unless you have the nut loose and are adjusting camber. You should check torque on the nut, which is 74 ft-lb (but given the space available you might have a hard time doing that with an ordinary torque wrench) and put a paint mark on the nut and the area in question to determine if movement still exists. Some generic alignment shops will fail to properly tighten those nuts to spec and you'll end up with situations like this.
mrgroove,
Can you update us on what you find? I just looked at my car in that same location and one side looks exactly like yours. However, nothing moves when I jack/pry on the lifted wheel. I am pretty sure that my alignment is tight and nothing is moving around. Just had the car on the track pushing it and it felt as good as ever.
very curious what you find out.
-Paul
-Paul
The surface under the eccentric is machined flat but it doesn't have anything like a polished finish. Here is a slightly better picture, which still tends to exaggerate the finish (the part that isn't obscured by the shadow, that is):
Sorry everyone. Just had a chance to look under my car and I was remembering the adjustment point further back (directly under the sway bar mount).
Mine looks a little polished up at this location but nothing is loose. You can see the other bolt further ahead and to the left.
Hopefully your car is fine.
Just picked up the car - the alignment chap stated that what I was seeing is where the bolt was before the re-alignment. I guess what I was seeing was a nice shiny piece of aluminum from where the bolt was originally when stock before I lowered the car which necessitated the alignment!
Sorry for everyone who crawled underneath their cars to take pics...
I still have a knocking though on the drivers side rear? If I drive down the street and weave from side to side I hear a knocking. Almost as if someone was tapping the wheel arch - kind or a tinny sound...
Any ideas chaps?
Any ideas chaps?
Any ideas chaps?
Any ideas chaps?
I have this same thing going on with mine; I looked under the car last night and have a little 'shine' under the bolt also (only had my Pcar for a couple of months so I don't know when it might have been aligned) but everthing is 'tight' under there. Please let me know if/when you find out what is causing your 'noise', as it is very disconcerting!
Thanks,
Patrick
I had a rattle in my rear end and the sway bar bushing bolts were loose. Actually it was the two bolts in the picture two posts up holding the sway bar, plus the ones on the other side.
