Does the B&M SSK actually damage syncros
Driving my C4S has been total bliss - but the throws on the shifter are just too long for my taste (especially after a couple hours in the S2000).
Getting through the posts regarding various SSK options (OEM, B&M, OEM GT3) I have read a few posts that suggest the B&M actually causes syncro damage. Is there any proof of this?? - or is it just a theory (shorter throw = faster shift = less time between gear change = mashing of the syncros)?
My personal preference would be to make the throw as short as possible without making the shifting effort overly cumbersome...
No SSK's do not damage sychros. They simply reduce the travel of the shifting mechanism. That's it. Think of it this way. You're still pushing in the clutch, and selecting a gear and then re-engaging it. Simple as that.
C.
C.
It will accelerate syncro wear if you are not gentle when rowing. The rubber in the factory shifters help to prevent you from forcing the next gear.
True, but the SS does what you "tell" it to. The factory ones will let you know something is not quite right. The SS has no choice, haha
I am all about SS shifters, but in time, they more than likely will accelerate syncro wear if one is too forceful and careless. Seen it many times in other cars. I, myself included.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
LOL.
Thanks for the info - I suppose its time to order the B&M. I don't know about the install though - I'm not sure I have the guts to remove all those interior panels....
Plus, I'll need a new shift ****. That Carnewal site has awesome stuff but 500+ for a shift **** seems a little crazy.
LOL.
You won't regret it.
This was asked in Panorama several months back. The quick answer is the SSK increases the chances of synchro damage due to the shortened time it takes for the synchros to engage and mesh. The editors did recommend AGAINST it.
The later model cars had the option for the OEM SSK. I presume that these model years had some changes done to the tranny and synchros themselves to allow that, since the SSk was not offered for the earlier years as an OEM option. In my 2005 987S, improved synchros were touted as one of the evolutions for that year. Unfortunately, my 2002 model year C4S is not as "evolved", did not have the SSK as an option, so I'm sticking with my OEM shifter. I actually like the length of the throw anyway.
Yeah, it can wear the synchros faster. The only reason is, like any other ssk, is because it's possible to shift faster than the normal shifter. The faster you shift, the more strain it puts on the synchros to get the gears up to matching speed.
Just don't slam the shifter as fast as you can and you'll be alright.
