pss9'S VS. pss10'S, Opinions?
After almost 8 years and 48,000 miles the shocks on my 2000 C4 Cab are getting pretty bad, ride just isn't what it used to be. Recently one of the rear shocks started leaking so now it is time for an upgrade. I had been considering a set of PSS9's for some time now. Until the release of the PSS10's the best prcing I had seen on PSS('s for a C4 was about $1,800 + shipping. Now I can get a set for less than $1,700, delivered. However, the Tirerack has a set of the PSS10's for a C4 for just over $2,300 delivered. So about a $600 difference. the question is, is it worth it to pay the extra for the PSS10's. One more setting, easier to adjust, and a more linear progression on the settings are the major differences.
So are their any opinions out there ( I know there is usually a derth of opinions around here)?
What does one more setting really mean? Is is actually stiffer or softer than the PSS9s or is it "Mine goes to Eleven" marketing fluff?
Some comments: It's fun to play with the damping but to me the most significant change to the car's handling came from the lowered ride height (less nose dive under braking) and the ability to dial in a little more negative camber. On the street I don't like the fronts to be "full firm". If you have to brake hard on a rough surface, stiff front shocks send you into the ABS very quickly.
With a lowered car you must be conscientious. Don't let rear tires "descend" from a curb simultaneously. I smacked the oil pan once. Only a small scratch resulted but I had to swallow my heart down out of my throat.
