alternate 17" tire sizes
I'm currently running 205/50/17 and 255/40/17 tires..
I'd like to know if I can get away with running 215/45/17 in the front....
checking on tirerack.com the stock size tire diameter is 25.1" (treadwidth of 7.5")
the 215/45/17 diameter is 24.6" and (treadwidth of 8")
the 225/45/17 diameter is 25" (treadwidth of 8.3")
I'd like to keep the rears @ 255/40/17 (stock)..
is there any problems with these increased front tire sizes... hoping this will decrease understeer a bit... but the main reason I want to change the tire size is I want the Bridgestone RE01-R which don't come in the standard front size...
Assuming the wheels are wide enough (7" will probably do but check Bridgestone's specs for minimum wheel width), I'd go with 225/45-17:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/50-17 4.04in 12.54in 25.07in 78.76in 804.4 0.00%
215/45-17 3.81in 12.31in 24.62in 77.34in 819.2 -1.81%
225/45-17 3.99in 12.49in 24.97in 78.45in 807.6 -0.39%
