Slightly rougher idle
It is programed for open loop, using the values of the MAF. In closed loop, the O2 sensors make final adjustments.
The MAF IS part of the idling formula. The MAF consists of, not only the flow of air, but IAT and engine load calculations.
At idle the air flow does not change - so the MAF voltage should not change.
So, disconnecting the MAF will have no effect on idle - the DME will simply see that it is not changing.
I stand behind what I said previously - clean your throttle body. On egas cars this is 99% of all idling problems.
Second, I thought the sensor on the side of the right intake plenum was the IAT? The one you disconnect and the engine lid fan turns on.
That is the engine compartment temperature sensor. There is a different temperature embedded in the MAF to sample intake air temperature.
Of course the MAF plays a role in the idle of your car. That is why the car is able to idle properly when it is 0F and 100F outside. The DME using the signals from the MAF at idle to calculate airflow and air temperature which helps calculate engine load. Without these parameters, how would the engine know how much fuel to inject? There is a hell of a big difference in the amount of fuel you need at idle for 0F intake temps and 100F intake temps. Timing is also affected by the MAF signal at idle.
You can prove this by decreasing the current on the white/black MAF wire and you'll find your idle will stumble in open loop because the mixture will be too lean. There is a middle of the road default mapping for times that the MAF is inoperatable. Works well in average temperatures. This is why a signal range is specified for the MAF at idle. IAT is part of the airflow calculation of the MAF.
The sensor for the engine compartment fan has nothing to do with the intake system.
Ok - I think you guys are missing my point.
At idle the air flow does not change - correct? The air temp might change slightly.
So, if you unplug the MAF - the DME can and does compensate (both readings don't change).
If you had a good idle prior to disconnecting the MAF then it will still idle good - if your idle was rough before disconnecting the MAF will still not affect the idle. Try it, I have many times and the idle will not change. After a while you will eventually get a CEL - because the MAF is disconnected.
Don't get me wrong the MAF plays an important role in measuring air flow amount and intake air temperature - but these have almost nothing to do with a rough idle.
Back to the original problem here - I still stand by my prediction. In 9 out 10 cars with a rough idle cleaning the throttle body will bring the idle back to normal.
My 996 bumps down about 30-50 RPM at idle. I will check and clean the throttle body when I get a chance
Reanimating this old thread..................
The engine stopped yesterday as I came up to a stop sign and easily restarts but won't idle at all.
If I drop below 1500rpm it dies. Managed to baby it to Indy about 15 miles and it only threw a CEL half way there.
Indy called this morning and says the MAF is dead.
After a search on this site this morning, it is conflicting information as to whether the car can idle with or without MAF connected. If my MAF is fried as Indy says, thenI would conclude that your car won't idle at all.
Dealer wants to sell new MAF to Indy for over $600.00!!!
Pete
Pete
But, I am prety sure car will idle without MAF
I would have started a new thread but thought it was relevent enough not to.
I can tell you that at least in my case, as soon as i let the rpm drop below 1500 or so, it would shut down.
I've ordered a new MAF from the following web site at $282.89 Cdn they also seem to sell in USA.
http://www.bimmerspecialist.com/
I hope my Indy was right in diagnosis after reading CEL otherwise I've just bought a MAF for nothing!
Pete
