RoW M030
Just so I get it straight, you said both use the same sway bars, but the additional work is to change the sway bar? Do you mean that you have to detach & re-attach the new swaybar links to the new strut body, but the sway bars are the same..OR...the sway bars are physically different but the same diameter? Thanks for your help, I seriously appreciate it!!
The sways for the standard suspensions are smaller.
The article in the PCA link in an above post explains everything in detail.
Still plays with cars.
Done properly I would not be surprised at 6-8 hours to install an ROW M030 especially if you do a proper alignment and corner balance at the same time. You WILL NEED a 4 wheel alignment after the swap.
best,
best,
There is nothing to corner balance as the shock and strut bodies are not threaded for height-adjustable perches. Unless you shim the stock perches or something, which could get very time-consuming. The OP quote of 12 hours labor was not including alignment. It's an excessive quote, as several here have indicated home garage times of 4-6 hours (less alignment).
But, hey, everybody has bills to pay and maybe his shop has a racing addiction to fund or something.
The M030/ROW M030 sway bars are larger diameter than the standard sway bars. They come with different bushings, but use the same mounts.
Another data point, my shop took 10 hours to install and align and rebalance 2 wheels. this was on a C4 and he said the 4 added about about 4 hours extra. Good shop, which had done other M030 jobs before.
Fantastic upgrade, still very streetable, but a lot more fun around the track.
