Loose steering at speed
Anyone have a fix for this? My car (99 C2, w/ aftermarket Aero 1, orig fact 17" wheels, Goodyear F1 all season) steers beautifully at normal speeds. I have had a couple opportunities to get the car up over 90+ mph (also had a full tank of gas), and the steering is a bit twitchy and loose, not nearly as planted as I would prefer. I get little or no vibration, so I'm thinking the tires are properly balanced. I'm looking at larger wider wheels right now, and will fit them with sumer tires. Maybe that will help a little also.
Right now, I won't be driving down the Autobahn at 150 anytime soon, it would be terrifying.........
Mitch
Mitch
Still plays with cars.
If you have the rear wing you need the deeper front spoiler. Alignment is also suspect, the settings are fragile and can be knocked out easily. Car should be rock solid at speeds of 150 MPH.
My tire pressures are 34F 34r for 17" tires. My front bumper has an aftermarket GT3 piece, and it has the lower lip added into the general molding. I took a measurement and the front center clearance is 6 1/4", the back edge (right before the wheel) is 5". So it tapers from the front, downwards. Is this correct? Stock ride height. I'll get a pic of it, and show you guys what I mean that the "lip is integrated with the bumper". Looks a bit ****ty to me, maybe I should spring for another bumper, and will do so if this is causing problems.
+1 There is a sticker on the car with the tire sizes and pressure. I recall its 36F 44R with recommended tire sizes.
This is what I was talking about- the add on "lower lip" is actually part of this piece!
Attachment 264753
Attachment 264754
Attachment 264755
Attachment 264753
Attachment 264754
Attachment 264755
Thanks. I have a dream job, I pass gas in my pajamas all day.
Back on topic, I just checked the bible and it says 17"- 36psi F&R.
The 17" wheels may be part of your problem. I felt a huge improvement in higher speed handling when I upgraded to 18" wheels.
