Proper way to measure non stock suspension ride height
Thanks Chao
Have not seen many pics of your 996, always liked the Aero in silver. You own a fine example of such. Good to see more/better pics of it.
Africa and Asia? sh*t, I'd take that kind of business any day. As a matter of fact let me know if you are in need of an executive assistant, will carry your brief case, an umbrella, arrange lunches and even set you up with some classy company
for your diners. All this at no additional cost to you, just airfare, I got no problems sleeping in a tent
Happy travels/safe return
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
chsu, your car is perfectly setup for a bigger lowering job on 19s. seriously, consider it. keep the stockers for a rainy day, but man your car would look amazing on a set of champion RG5s or something functionally good looking like that.
Ben does have that eye for these things. As BruceP is like the professor, Ben is the designer.
If I had some of that Benjamoney for my 996...
No doubt about those Aero's though
I know Ben's got a good eye about it and agree 19s would fill the car out better. However, I run 18s in winter tires and don't want to deal with alignment twice a year. There is also another cost of paying for more expensive tires in 19s and selection if them are not as plentiful.
Some of the stock styles I would make a priority to switch into the aftermarket.
Not the case for either one of us, IMO.
also, tell me what's so limiting about tire sizing running 19s that fit. just want to understand what you're understanding.
That is what my mechanic told me when I went in for an alignment. I did not question the physics behind it. Maybe its that I need to do the alignment with the bigger wheel to allow for space and proper set up. When the 18s go in during winter, then it just looks out of porpotion.
Tire limitations are just in supply qty not sizes that would fit our rims.
i don't know how often u change tires, but tire selection is a aplenty for the typical 19 wheel sizing on the 996. like i'd run 19x8.5 19x11. ps2s, no issues. continentals, whatever else i'm sure is readily avail.
think it thru man. you're not pioneering anything here. it's been done many a times.
that's some weird advice. if the wheels fit, they fit and u don't have to do any voodoo camber settings to get them tof it whether at stock height or lowered.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Update from a lunch visit to the mechanic. Due to the wheel well shape, I will drop it 1/2" and no more rubbage...
