996 Forum 1999-2005
Just How Stiff a Ride Should I Expect
Old Feb 29, 2008 | 01:27 PM
advent996's Avatar
advent996
Default Just How Stiff a Ride Should I Expect
Obviously it's subjective, but just how much stiffer will my 996 become after changing from US to ROW030 ??? I'm not saying I'm in favor of the wife's TL but not looking to tear up the kidneys either !!!
Old Feb 29, 2008 | 01:52 PM
Doug Donsbach's Avatar
Doug Donsbach
It isn't that much of an increase in spring rate - only about 30% in the rear and less than 20% in front, with roughly proportional increases in the antiroll bar rates. It's a nice improvement, and you would probably only object to the ride if you spend a lot of time on broken pavement or rough city streets.
Old Feb 29, 2008 | 02:38 PM
Paul 996's Avatar
Paul 996
Stock is "soft and compliant" (is a porsche supposed to be this soft), M030 is sporty (this is what they had in mind), x73 is STIFF/firm (you better like a rough ride and have ideas of tracking it a lot)
hope that helps put it into perspective.
Old Feb 29, 2008 | 03:06 PM
Chads996's Avatar
Chads996
Something to consider if not already mentioned. When swapping out springs, there is a bit of settling time. They will seem a bit harsh at first, but will "break in" as you use them.
C.
