ROW 030 for C4S with part numbers
I did a little research today while at Vertex.
USA front shocks have the same part number as ROW 030.
Both are 996-343-043-26.
The rear shock part numbers are different. The ROW are 996-333-051-40.
Springs are of course different.
996 343 533 30(504) pink/blue Front
996 333 531 49(504) blue/red Rear
All these parts are for a c4s coupe. Cabrios have different numbers, if someone needs them I can post too.
I didnt have time to crossreference the sway bars.
I think I am going to do only the springs because its much cheaper and I might eventually change to something else.
Rene
Rene
Are you going to put them in yourself? A big part of the cost is installation, It seems foolish to me to go through all the work and alignment to just change the springs and not go to a new shock matched to the spring. Just my opinion. I'm running the x-74 suspension (yours would be x-73) and I love it.
andy
andy
I wont be installing it. I have a friend that will be doing it at his house. He knows what he is doing and only works on porsches.
I dont think it will make a huge difference since the C4S comes with something like USA 030 shocks although I dont really like the rebound on the rear shocks.
I wish there were more C4S out there with suspension mods. Searches really havent turned anything up.
I hear the X73 is firmer and I'm sure the other options out there are the same (i.e. JIC coilovers, KW coilovers, H&R coilovers, etc)
I have these alignment settings and so far so good:
-1 deg front camber
0.36 front toe out
-2.5 deg rear camber
0.4 rear toe in
I suppose you are doing this just to lower it to ROW height? Just the springs should be alright.
Doing the full X73 lowers the car more and stiffens the car up noticeably. My regular drive goes through a fairly long segment of open highway with bad expansion joints. It was bearable with the C4S OEM sports suspension. With the X73, I have to keep reminding myself of how excellent the car is at the track each time I go through that highway. It is especially noticeable for me, 'cuz I have a sofa on 4 wheels, aka Volvo, as my DD.
I am doing it to loose some under-steer and level the car out. I dont like the way the car sits higher in the front than the rear. Hopefully by lowering the front it will put more weight on the front gaining some steering.
. Heh-heh, that US heads-up stance can indeed be quite bothersome. Darn the US bumper height laws. Not so sure the minimal lowering with the ROW springs will correct the inherent understeer that much, though.
If you are more after improving performance, here's a little trick with the C4S that does not require changing the suspension. Slow in, fast out. Be a heartbeat slower at turn in, get on the gas a heartbeat earlier before the apex, and you'll find that the AWD front wheels will dig in around the apex . You'll find your exit speed noticeably faster than our RWD brethren, and you'll maintain that speed advantage all the way down the straight as you pass them.
Rene
Rene
I'm pretty sure you have part of this incorrect. I went through this myself last Fall for my C4S. It is the front (not rear) shocks that are different. Logically this makes more sense, because the front lowers far more than the rear. I had several conversations by email with Gert Carnewal and then phone and email with Suncoast. Gert insisted that all four shocks were different. Suncoast could find no different part numbers for rear shocks, so I didn't change them. Both agreed that sway bars are the same. I did the install last Fall. It was a great change.
Mike
The parts for front struts, front springs, rear shocks and rear springs are ALL different for ROW C4S.
I highly recommend you have this done at a dealership. There is no need to change the rear, the 10mm difference will not help the problem in the nose. The front ROW C4S springs and struts (both 20mm lower) will make a HUGE difference on the track. You will however lower your front spoiler by 30mm if you elect to modify only the front geometry. I found that running 245/40/18 front and 335/30/18 rear tires corrects the scraping spoiler problem, and doesn't hurt around corners either...
I am going to recheck the part numbers but I am pretty sure they are the same. I know that some of the numbers superceeded other numbers. Maybe they were different then and the same now?
I have all the printouts infront of me except the ROW front shock. If anyone has access to PET it is illistration 402-01 hopefully they can post the part numbers for the shocks.
