X51 Oil pan revisited: Chads996 Baffle option Update
J3 Baffles update - READ CAREFULLY
The baffles are 95% complete. Pricing will be comparable to the stock plastic baffle system, but will be the following:
Details:
1. Custom metal baffle doors (welded to baffles)
2. CNC cut stainless panels and frames
3. Teflon "gaskets" around edges to help seal baffles area to pan/block
4. Bolts directly to any stock 996 3.4L & 3.6L oil pan
5. Dimensions are similar to X51 oil baffles
6. Pricing will be comparable to stock baffles.
For ordering this baffle, please contact J3 Motorsport individually as I do not have any affiliation with them.
J3 Motorsport, Inc.
4991 B.U. Bowman Dr., Suite 100
Buford, GA 30518
Phone: 866.856.5454
Fax: 770.831.6221
Ask for David and mention Rennlist
I will be pulling the prototype in my car out and putting in the final product. Photos are not available as of yet. They still waiting for some of the CNC parts to arrive.
C.
Details:
J3 Motorsport, Inc.
Buford, GA 30518
Phone: 866.856.5454
Fax: 770.831.6221
C.
What he describes is currently available from EBS Racing with metal doors instead of the rubber used on the OEM Porsche X51 baffle.
http://www.pelicanparts.com/More_Inf...SVSVSI=916.htm
So it did work as intended.
Nickshu,
What year and tying car are you running? The 05 -08 Carreras's oil pressure gauge has some kind of 2-3 second continuously averaging thing going on - which unnoticed severely damp quick and Brief drops in oil pressure. It becomes harder to detect oil pressure drops than the 996 cars. I just switched from a 996 to a 997.1.
I'm surprised the different trapped door x51 version actually worked.
Nickshu,
Here is video of WGI in May,
