Garage Door Opener into a 996
#32
You could also get one of these Home link units from a Cadillac (EBay $10 - $30) and stick it to one of your cubbies or ?? with auto trim tape. Drill a small hole in the back of the cubby and run the wires to the phone prep connector. Works great especially if you have more than one garage door to open. Try to buy one with the connector & some wire on it to save having to solder the 2 wires on.
#33
Glad you did -- I hadn't seen this garage door mod -- now I have to do it. All of my existing switches are gloss, so I don't think I'm going to get the targa switch (that only comes in a matte finish). Does anybody know if Porsche makes a blank glossy switch (in other words, with no markings on it)?
At the risk of continuing a "necropost" I can post pictures of the differences of the spoiler, when I get it, and targa switch if anyone is interested.
#35
Here's another step by step guide to assigning a switch in one of your unused dash buttons to open your electric garage door.
https://www.youtube.com/watch?v=kxe1RYHYQXg
#36
#37
Did this one to mine last week. Haven't hooked up the light but I will do that soon. One thing to mention, the range was cut in 8th. I went from 50 yards or so to open the garage door to right in front of it before it gets signal. Not critical and love the slick use of the targa switch, but worth noting.
Cheers,
D.
Cheers,
D.
#38
For the record, I did this mod 5 years ago, using a Targa switch in the center console (don't have heated seats, so used one of the blank spots).
Works great! Ran a line from one of the window switches to provide light at night. I've never changed the battery, and NO problems with signal range. I was concerned about signal degradation, but even with the guts buried in my console, it works as well as it ever did.
#39
Cheers,
D.
Cheers,
D.
I am planning on doing this, but will use a HomeLink module like this one from eBay (http://www.ebay.com/itm/BEIGE-NEUTRA...4AAOSwjTlZgCll) so I don't have to change batteries or disassemble to reprogram it. I don't know if I want to go through the work if the range is going to be too short as our factory HomeLink in an Audi has a pretty short range already.
#40
Can you share what type of remote control you were using and was it the same one you had been using before?
I used the previous generation of Genie that I carried over from my old garage door opener when I replaced it with a newer one. Didn't want to get into soldering in my new one as it has several more buttons and the old version just had 1. Made for a really simple install. I am going to move it around a little bit and see if I can't make it better. It might be setting on some foil back there or something.
D.
#41
I am thinking of doing this nice little mod myself . Assuming that i will put this device at the central console aboeb the PSE switch , is there an easy way to power this control unit as well and remove the battery ? has anyone done this as well ?
#42
I used one of the high beam openers. It sucked. I wired a $5 EBay switch to an opener and hid it in the center console. It was better. An opener hanging from the pax visor is best.
#43
Also, I would make sure you have something very solid to solder the power to inside the remote. If the internal remote battery holder has small and/or weak connectors, or tiny power wires inside the remote, then it might not be a good idea wire power to it in case the weak connectors break and you end up with a short. The HomeLink units have pretty solid wires to connect power to (you still have to disassemble the button side of the HomeLink to connect the Porsche switch).
