Misha Wing & Side Skirts, List to date Install
oh u are lowered on pss9s, all the more easier for you to make the biggest visualize impact on your ride which is to get a nice set of 19s.
yea, the offsets suck because the wheels are factory. they tuck in like an rv wheel when lowered.
don't bother with spacers. they suck. just get 19s and call it a day. though i have set of perfect OZs for sale, they won't fit your car as they're for c4s/turbo/gt2 fitment.
how about a set of champions? they make perfect 19s for narrowbodies... i believe 11s in the rear. don't go for anything less.
Newbies Hospitality Director
Jerry,
Since the C4 is a narrow body, I am guessing your wheels are 8" wide with 50mm offset on the front and 10" wide with 65mm offset in the rear. You coupd add 7mm spacers in teh front and 15mm spacers in the rear to get a more agressive look without and rubbing issues.
19" wheels will most likely be heavier than most 18" wheels and the ride will be harsher because of the lower aspect ratio needed for the tires. Additionally, 19" tires will be more expensive and there is not as wide of a selection in 19's as there is in 18's.
If you find some wheels you are interested in (18" or 19"), post the widths and the offsets here and we can help you determine if they will fit properly. This can keep you from making a big mistake $$$ wise.
I "think" I understand what you mean when you say "my front is further away it would need a bigger spacer and the back a smaller one." However, if I understand your statement correctly, I believe you actually have that backwards. On a given wheel width, the higher the offset number, the more the wheel will retract toward the center of the car. Three
Changing only the offset - If you have two 8" wide wheels, the 1st wheel has a 50 mm offset and the 2nd wheel has a 65mm offset. The 2nd wheel will RETRACT 15mm toward the center of the car compared to the 1st wheel. This means that relative to the 1st wheel, the outside (face) of the wheel will RETRACT by 15mm and there will be 15mm LESS clearence on the inside of the wheel.
So adding a 7mm spacer to an 8" wide wheel with a 50mm offset would be the same as having a wheel with a 43mm offset. By adding the spacer, the outside of the wheel will EXTEND 7mm more and there will 7mm more clearence on the inside of the wheel.
Changing only the wheel width - If you replace an 8" wheel with an 50mm offset with a 9" wheel with a 50mm offset, the new wheel will EXTEND an additional 13mm compared to the original wheel, and there will be 13mm LESS inside clearence compared to the original 8" wheel.
Changing both wheel width and the offset - It gets a little more complicated if you change both the wheel width and the offset. That is why is is good to have a wheel offset calculator available. This one is very good. Wheel Width & Offset Calculator I would suggest you play with different widths and offsets, using either your front or rear wheel specs as the "current" wheel.
If you already know all of this then I apologize for wasting your time with the length of this post. I hope this has helped. Please let me know if you have any questions.
Tim
Thanks for the info...I do not want to do this twice
If I measure the distance from the wheel to the inside lip of the fenders front and back the back is 1/4" +/- and the front is a 1/2" +/-
Here are some picks from the center of the rim shot strait up...as well as new seats installed
first pic, front
second Pic. rear
So is that 15mm front and 7mm back???
first pic, front
second Pic. rear
There is more space in front than in the rear, but you also have to remember that your front wheels will be turning. Many guys here have done 7mm spacers in the front and 15mm spacers in the rear without any rubbing issues. I think you "could" do 15mm in the front, but I do not recall anyone doing that.
spacers this spacers that... if u wanna do it up right, i'm sticking to my guns and recommending that you get a set of lightweight one piece champion wheels with perfect width/offsets so you don't have to go about like a science nerd and measure everything to add something to a car that is in my opinion superfluous.
19s ride harsher.. you guys seriously that old and fragile or am i just a very tolerant, open minded individual?
If I keep these as track tires? I want to get them out, so I will need spacers for them...
the other problem is, If I order 19" I do not want them to look like this,
Tim do you think I might have goofy rim's, with that much space up front or is that usual??
Ben I agree they look like an rv
4-large, can't help u there as i have no idea what your stock wheel offsets are, but i'm sure if you do a search you'll find it or just hope someone who does mess around with stock wheels would know (likely gota911, et al).
i'm sure you won't be the first to tack on spacers on stock wheels.
19" wheels will ride harsher, there is not doubt about that. Anyone thinking about switching to 19" needs to be aware of that. You "push" for 19" wheels quite often, totally for the "bling bling" factor, but I don't recall you ever mentioning the harsher ride that comes with the 19's. Like many things in life, there are usually trade-offs associated with changes, and there certainly are trade-offs assiciated with going from 18" to 19" wheels. I am just trying to make sure all valid points are brought up so someone can make an informed decision.
Oh Ben, one more thing. Just because I'm older than dirt doesn't mean I don't appreciate good looking wheels!
Tim
Do you think I might have goofy rim's, with that much space up front or is that a usual amount of space?? is this a stock set up???( I dont know)... I got the car used so ????
Thanks for your help
jerry
jerry
