Failed Emission: Evaporator Vent Ctrl Malfunction
No need to be sorry, all feedbacks are appreciated. Im just trying to get an idea of the culprit. Thanks.
P0446 EVAP Canister Shutoff Valve (Function) - Below Lower Limit
The task of the shutoff valve is to seal the purge air line to the EVAP canister during the (US required) fuel tank leak test.
Probable causes:
- Purge air line blocked.
- Flow resistance of EVAP canister too high.
Probable causes:
Probable causes:
Probable causes:
Got it, thanks Loren.
ok i got the list of parts been replaced:
purge EVAP flow too low
VENT valve been replaced
996.110.129.52 VENT LINE-S $83.05
996.201.221.07 CARBON CANISTER-S $194.76
