How to Remove Door Panel (DIY)??
Does anyone have some good links to door panel removal? Tools needed? I seem to remember that there was one at one time but did a search and could not find it. Thanks.
I saved part of a post recently, but I regret that I didn't identify the author:
I pulled the door panel as per
http://www.ecoutez.net/boxster/door-panel-removal/ (thank you!) and
http://forums.rennlist.com/rennforum...d.php?t=392254 (thanks!) and removed the insulating sheet. Took about an hour going slowly and carefully.
Good luck!
Good luck!
Looks like a PITA from that Boxster thread (disconnecting the battery and all). I've seen threads on this forum that make it look like removing a few screws and you're done. Do a search for one of those!
door panel
Andy T
