Water Wetter and other Automotive Myths
If the product, Water Wetter, reduces the water temp. by 15-20 degrees as claimed and the the thermostat would insure that the coolant temp increases up to a certain temp. then why in God's name would a person use it? It just retards the initial temp. increase that one needs to run the engine at optimum condition and later the temp would catch-up with it!
Explanation, please?
Racing and heavy track applications are recommended for this product. It DOES work. In fact, the only reason for coolant is to prevent water from freezing in cold temps and allow the water to work efficiently within the engine.
A lot of racers run water only. Water Wetter helps make the water more efficient but reduces the problems if a coolant lines goes ka-bloom on the track.
Good stuff, but again - only for use in track cars.
C.
C.
To add a little more, as a racer I am just as concerned with oil temp as I am water temp and in cold conditions even more. The water gauge will show normal temps but the oil temp will not even be close to a safe range especially in cool conditions. It usually is well into the warm up lap before the oil temp is up enough to be race ready. Be very careful thinking the water temp gauge is telling you all you need to know.
It works...and that is that. It might be a myth to you but to people that have tried the product, it is simply a product that works.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I don't buy it. Surfactants are useful for surfaces that the water can run off of. In a closed water circuit, where else can the water go? It may prevent air bubbles in some circumstances, however.
Surfactants are very common, cheap, and effective in extememely low concentrations (200:1). Any antifreeze should already contain adequate surfactants, I would think.
And yes, the thermostat controls the water temp, regardless of coolant. That phrase should be a tipoff to hype.
Not sure what "Water Wetter" does, but running straight water for cooling makes sense scientifically. Water has a higher specific heat capacity than just about any other liquid. That is, water can absorb more heat (energy) per unit mass than most other liquids. That's why racers use it when cooling is all that matters. Of course water alone has no corrosion or anti-freeze protection so it's not for everyday use.
I will vouch for water wetter, worked in a friends 'stang. Many dynos were done (Muscle Mustangs and Fast Ford mags) using water wetter in the intercoolers of Lightnings with some minor hp gains. Couldnt tell a difference in my Lightning but 5hp gain in a 5500 lb truck is hard to notice.
I think it is important that the main market for this product is an additive to an all water system when you run in races (most wheel to wheel organizations have these rules) that do not allow your cooling system to contain any anti-freeze. Anti freeze on the track is a very bad situation. I don't know that the benefits in a traditional coolant mix are all that great....but in an all water system, it works great.
Since I run this stuff in my race cars I agree with everything Chad has said except I don't understand the burst hose comment? It doesn't do anything for that condition as I speak from experience.
C.
I use water wetter in my 964 race car at the track all the time.
The only positive effect I would see is come anti-corrosion and anti-freeze properties w/o the slick anti-freeze problems.
Adding ANY non foaming water soluble lubricating fluid to plain water will increase the water's cooling effect. Adding 5-10% antifreeze to plain water will give the EXACT same cooling results as will the more expensive gimmicks. A properly setup cooling system will keep your engine more than cool enough running a 40/50 antifreeze mix anyway, so maybe the focus should be on what is wrong with your cooling system rather than what is in your cooling system.
http://e30m3performance.com/myths/mo...ter_wetter.htm
My race cars have all Red Line in them and as good as their products are if they make it I am for it
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
