Creak from front control arm, ball joint?
Sorry if this has been addressed, I tried a search but didn't find what I was looking for.
Anyway, I'm getting a creaking noise from the right front lower control arm. I'm thinking this is a ball joint going south. If so, how hard is this to replace, can I do just the ball joint or do I have to change out the entire arm? Am going to get it in the air this weekend so would really appreciate some info on this.
The arm must be replaced. The proper ball joint removal tool makes the job much easier.
Last edited by Doug Donsbach; 11-07-2007 at 06:15 PM. Reason: Use balljoint pic instead of steering knuckle pic.
I just got the parts in and I'm waiting for the tool to come in. I'll let you know how difficult it was once I get done. It doesn't look too bad, but things like that can be deceiving so I'm reserving judgment.
Thanks Doug, darn, was hoping for just the joint.
http://www.napaonline.com/MasterPage...oint+Separator
This was referenced by someone else on the renntech forum. They used it with no problem.
