Clicking noise rear wheel area. have a listen.
Well it's not the tranny, but the CV Joints inner and outer both sides. They had hardley any grease and when removing the boots found water coming out out of them so I cleaned repacked and reinstalled. Ran through 2-3 gears and no noise so far, but it is still on jacks. The bad thng is it took all day and man was it messy and when I finished I forget to get hand cleaner. Thanks everyone for the suggestions.
George
I am soooo tired right now
I'll put the tires on tomorrow and maybe take it for a spin down the street then it's off to the dyno if it checks out.
I need to find out from vivid racing how they take there A/F readings etc.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Real nice diagnosis...but wait... how old is this car? how many miles? are the CV boots cracked? Leaking but you would have easily spotted grease everywhere... water in all the CV joints? WTF... it sounds like it left the factory without or with minimal grease... Hope this is not a QA problem...
George
George
Forgot to mention george it is a 2000 carrera with manual trans and if I was doing maintenance it would be easy check to pull the boots back and inspect and repack if nessecary for piece of mind.
Here's a diagnosis tip for the next time you have a noise coming from the driveline: drive along listening to the noise and then see if the volume or tone changes when you veer from left to right (back and forth). That will load up the CV joints and the suspension on one side at a time and help you pinpoint if the problem is on one side or the other. If your problem was poorly lubricated CV joints your weird noise would have been more pronounced turning one way over the other (unless you had the problem on both sides, in which case it would have been more pronounced at the apex of each back-and-forth turn).
