Portable GPS Mounting Ideas
Hi All,
New here, having just purchased my first Porsche, a 2003 996 coupe. Pretty basic with very few options. I ordered a Garmin Nuvi 660 GPS with Blue Tooth, which just arrived. I'm in California, where it is illegal to mount these on the windshield and so I'm hoping some of you can suggest other options that do not leave any lasting marks, etc. to the dash.
If you have some ideas, please share and, if possible pictures of your solution would be great.
Thanks!
Roger
Thanks!
Roger
Garmin
I have the Garmin 360, which is a bit smaller. It is mounted to the inside, underside of the plain parcel shelf with the stock suction mount. The A/C adaptor is hidden near the fuse box, and the accessory external antenna is threaded through to come out near the alarm light on the dash. I think the 660 is a bit bigger, but it may still work.
Stefan
Stefan
Go to www.kudausa.com
They have a lot of lower mounting ideas for the nuvi. That's where i ordered mine.
Government in-action!
No doubt in the interest of 'driver safety/reduced distractions/reduced visibility' they made it illegal to easily mount the gps up high where you can see it without taking your eyes off the road (my personal preference being on the lower left next to the dash and a-pillar) and instead make you bury it somewhere down next to the gearshift.
If you don't like the other center console mounting options you could also buy one of the older factory 'snap-in' cupholders that mount over the drivers side a/c vent. It's cheap enough that you could drill into this, attach a bracket and put the gps on it.
Roger
BrandX....I went to the Garmin site and couldn't find any reference to a cupholder mount for the Garmin. All sorts of winshield mounts, weighted mounts, suction cups etc....but I couldn't find the cupholder. That seems to be the least intrusive of all the ones offered and I'd like to see a picture of one.
Do you have a link to that particular mount?
Chuck
Chuck
Chuck,
BrandX refers to www.mountguys.com, which does show the cupholder mount; although too little detail to really see how it works.
Roger
Roger
Deano: I went back again and found the ad for the cup holder mount...but like you said, there's very little you can see. I think they do that on purpose to keep folks from copying the design. There was one post sometime back where one of the Rennlisters actually made one out of a piece of 3 inch PVC pipe cut to size. I would imagine that the cup holder mount would be fairly simple...just an insert that fits the cup holder.
Maybe BrandX would accomodate your request for a picture....a better shot than the one they post on the ad....
chuck
chuck
Chuck, It's as if you read my mind. Yesterday afternoon I got to tinkering in the garage and pulled a plastic lid off of a spray can and inserted it into the cupholder to see what's what. I think that if I get a piece of pipe as you described and cut it to be just about flush with the top surface of the cupholder, then glue a slick,flat round piece onto it--larger diameter than the cupholder hole--then I think it will be snug enough to hold the actual Nuvi mount. Snugness is, I think, the key. Another thought along these lines would be to cut notches in the bottom end of the pipe such that it sort of "locks" over that rectangular piece that keeps a cup from falling through. Does that make sense? Anyone else out there tried this?
Thanks!
Thanks!
