PSS9's - Need New Sway Bars?
Good discussion folks, but as others have suggested changing the sways is NOT required when upgrading to PSS9s. Install the PSS9s and then drive it. I actually was considering the sways...had a professional driver take my car out on the track....he said DO NOT do the sways...it was already stiff enough virtually no roll. I have no problem with roll aggressive street driving in a cab!
So it sounds like if you buy PSS9s and want to do swaybars...
a decent option cost wise would be to buy M030 swaybars and use the stock droplinks - this should be good for street or GT3 swaybars....if they use stock C2 996 drop links,
or buy any other aftermkt swaybars and also buy droplinks .... which may be a better option for Street/Track but more costly
It's the GT3 bars, TRG, and others that change the shape of the end of the blade on the sway bar to creat an adjustable bar that requires the aftermarket drop links to be used.
No matter what the rear bar is you CAN reuse the stock links...however some still upgrade the rears links too for a beefier unit as the stock links can bend and break.
Andy
good point as the PSS9 install will change the ride height.....
Any recommendations on adjustable Droplinks?
Adjustable droplink uses metal bushing and overall construction is more rigid.
It rides more reponsive and should feel it in corner handling. OEM droplibk may not be strong enough for a bigger diameter swaybar, as I blended the front OEM droplink with OEM swaybar.
I bought mine from TRG
http://www.theracersgroup.com
You can also try:
http://www.tarett.com
You can also try:
Gents I'm not trying to agrue the point of the adjustable droplinks...but from personal experience you need to really evaluate the purpose of the car when thinking about these links. The heim joints will wear and develop play which will result in clunking as you go over bumps. It's not a question of if...it's when.
Also for a road car even with coilovers your heights are going to be pretty close corner to corner and you've not going to have excessive preload on one side or the other....and if you're driving hard enough on the street to notice the effects of this preload you're a danger to others on the road. For instance if you properly setup your car, corner balance it for your drivers weight, and then set preload on the bars when re-attaching them you'll be spot on. BUT as soon as you add a passenger you're going to get preload again. You just have to ask yourself if it's all really worth it in the end for your use.
If you track your car often the adjustable links and adjustable bars should be the only solution. For those of you who don't track think about the potential of added suspension clunks with the droplinks over time and remember that when making your sway / droplink decision.
Another option when using the adjustable front bars is to use a shorter OEM style link. This is what alot of guys did to their C2's when upgrading to the GT3 bar before the adjustable endlinks ever became readily available.
Andy
Andy
I had PSS9s installed and noticed a HUGE difference on the track and some difference on the street...obviously both positive. I did one event with the stock sways and then the next 5 DEs with H&R sways front and back. While the difference was huge going to the Pss9s I didn't notice much of a difference when upgrading to the H&Rs. I used the stock droplinks with no problems.
Just my experience. Hope it is helpful.
K
K
Here's a link that shows insite's drop links
https://rennlist.com/forums/for-sale-ads-member-to-member-fs-wtb-free/370324-fs-986-996-adjustable-sway-bar-drop-links.html
Thanks for the OP for this thread I've been on the fence on the sway bar choices. Sounds like the GT3 sways with drop links is A+. Does anyone know benefits that the H&R springs have over GT3's?
I didn't use the rear adj. drop links for the GT3 sway bars as the stock C2 drop links fit in the rear. For the front you have to use new, shorter drop links due to the different form of the GT3 sway bar. The H&R sways are IMO priced just to be a little cheaper than regular priced GT3 bars with new drop links; with H&Rs you can re-use all 4 stock C2 drop links. Insite's pricing for the front drop links and a cheap seller of GT3 bars (thanks to Paul996 who recommended Brandywine Porsche) were the main trigger for my decision to go with GT3 bars.
