PSS9's - Need New Sway Bars?
With the install of the PSS9's, is it necessary to also install new sway bars and drop links? I've done a search and some imply it must be done, others make no mention about doing anything more than installing the PSS9's. If its optional, what are the pros and cons to adding them?
I believe that you can reuse your factory swaybars and drop links. However I do suggest you upgrade. Most simply to the factory bars that come in the M030 kit. However if you have a C4 most people suggest you go to a heavier bar in the front because of the added weight of the front running gear.
How are you driving? Track use? Street? Aggressive canyon carving? I have a 99 C4 Cab with PSS9s and the stock bars....no issues, and I drive pretty aggressively, and the PSS9s alone are a nice upgrade. I will probably upgrade at some point, but I have felt no need with my type of driving. I would do PSS9's and if you feel you want more then upgrade your bars as well....On a C2 with normal to aggressive driving and not alot of tracking, then I wouldnt get the bars. On a C4 its more of an issue because of the additional understeer in the stock suspension.
Suspensions are made up of many parts that do different things. Shocks and springs are just part of the equation. They effect ride quality, squat, dive, set and recover. Swaybars effect body roll. You can effectively remove body roll by running your shocks stiffer, but you then also remove some compliance and ride quality. IMHO you really need to upgrade the whole package. This is not to say that you can't do just one part, it's not going to cause the car to blow up. You can certainly do it in stages. In my mind it doesn't make sense to go with a high performing suspension like an adjustable coilover only to cut corners by not upgrading swaybars. Again this is only my opinion and it is certainly not a necessity, but for the budget you put into your PSS9's you could have done Bilstein struts, H&R springs, new M030 swaybars and bushings or the M030 kit from Porsche installed. Again, and this is only my opinion I'm SURE others will pipe in with conflicting advice, but if you choose a system like the PSS9 that is really a mid level track suspension (height adjustable, damper adjustable, corner balance adjustable) you should go all the way and upgrade the sway bars too.
Since I entered the Porsche world coming from moding a number of different cars, this is the only forum where jumping into a coilover system is the norm. In most other performance circles I have found people just start out with springs and a sport valved shock, then sway bars and strut bars. It must be due to the abundance of money that P-car owners are willing to put into moding their cars.
You are welcome to disregard this whole post. I'm tired and just rambling.
In short, swaybars affect body roll (sway) in a car. Springs and Shocks or coilovers do not directly address this part of handling.
AA
PS to give some perspective I have upgraded suspensions on 4 various cars now
AA
AA
AA
If he isnt going to track the car, he wont really notice the difference. And the PSS9s are a GREAT street system....lowers the car, improves the handling while keeping the ride comfortable. I wouldnt call it a track system, nor do most track junkies, they say its too soft for hardcore track work, and JIC's are usually the suggested track coilover, yet they are a little harsh for everyday driving.
I respectfully disagree, how many times do we whip our cars around the corners... yeah not at 90 mph... but once you put the sways on it is night and day... They have more performance impact than the PSS9, on rollover... if anything sways should be the first mod before coilovers... the pss9 is great for lowering and adjustment and ride quality but stiffer sways just complements the adjustability... but I swear by sway bar mods.
Take the car out to a few PCA AX events as is, then install the sway bar to help dial in the suspension the way you want it. There is a noticable handling difference on the track/AX.
Sways bars with or swaybars w/o drop links? H&R does not have drop links - are these good fror street use or is it preferred to go with a swaybars with droplinks? I just purchased PSS9s - and I need to know this also
Drop links are required for ALL sway bars. The factory bars have a certain shape that dictates the factory drop links. However the aftermarket sway bars have a different shape that do not allow you to use the factory drop links anymore. Therefore if you buy the H&R swaybars you must also purchase droplinks so that you can attach them to the car.
The stock bars, and the M030 bars use the same stock drop links. I'm not sure about the stock GT3 bars. Someone can chime in here with an answer.
So it sounds like if you buy PSS9s and want to do swaybars...
a decent option cost wise would be to buy M030 swaybars and use the stock droplinks - this should be good for street or GT3 swaybars....if they use stock C2 996 drop links,
or buy any other aftermkt swaybars and also buy droplinks .... which may be a better option for Street/Track but more costly
