996 Forum 1999-2005
Help with Carrera badge...
Old Oct 10, 2007 | 04:32 PM
gota911's Avatar
gota911
Newbies Hospitality Director
WHen I swapped my black badge for the silver one, I wanted to make sure I got teh badge in exactly the right place so I drilled a couple of holes in the deck lid and inserted a couple of bolts then I ran a string between the bolts to align the badge (1st pic). It worked perfectly! You can hardly even see the bolt heads on the deck lid (2nd pic).
File Type: jpg
File Type: jpg
Old Oct 10, 2007 | 04:39 PM
michael.s.under's Avatar
michael.s.under
Damn drilling holes would have been a good idea, I used a hammer and self tappers!
Be aware Tim these days they will take you seriously!! See my post on wind drag on glass vs. paint!!!
Old Oct 10, 2007 | 04:53 PM
gota911's Avatar
gota911
Yeah, you're right about that!
BTW - do you think a little touch up paint will make the bolt heads invisible?
Old Oct 10, 2007 | 05:08 PM
michael.s.under
Ha ha, funny you should mention that, all I had lying around was that tree trunk paint, It matches my car pretty good. Who knew tree trunk paint was glacier white!!! Maybe Eric can make us some plugs!
Old Oct 10, 2007 | 06:01 PM
Rocketeer's Avatar
Rocketeer
Tim,
Can't quite tell from the picture, but I assume the bolt heads have a brushed silver finish...
BTW what size drill bit did you use?
Old Oct 10, 2007 | 06:20 PM
gota911's Avatar
gota911
Originally Posted by Rocketeer
Tim,
Brushed silver bolt heads? Yeah, you betcha!
I used a 3/8" drill bit. I thought about using a 1/4" bit, but since I was going to be using nylon string (none of that cheap cotton stuff for my Porsche, no Sir! ) and planned to stretch the nylon string really tight, I thought I had better "Biggie Size" it.
What do you think, did I do OK?
Old Oct 11, 2007 | 10:42 AM
MagnusB's Avatar
MagnusB
gota 911, your badge still doesn't look straight, you might have to drill another hole to get it perfect.
I used a metal ruler and scratched a line in the paint just under the logo.
Now I can replace it as many times as I want and get it perfectly aligned every time.
Might try the bolts and fishing line instead and fill in the missing paint with my fill-in pen..
Old Oct 11, 2007 | 11:01 AM
redridge's Avatar
redridge
Anyone have experience with the rennline pedals ?
they are the best imho.
Old Oct 11, 2007 | 11:05 AM
AndyK's Avatar
AndyK
Haa!! Cool, speed holes!! Helps get more air to the engine, right! And the bodies are galvanized, so you don't have to worry about rust! Great job!
You should have left the string there, to hang various ornaments during holiday time!
Old Oct 11, 2007 | 11:31 AM
Riad's Avatar
Riad
Chandler!
Originally Posted by TheSpeedDemon
What they said about removing it and marking it before removing it.
As for the colour of the badge, I thought it really depended on the oil you used in the car, or was that the colour of the calipers, or was that the brake fluid type and/or colour
Almost... if you installed a clear bra it was silver, otherwise it was black.
Old Oct 11, 2007 | 11:56 AM
Rocketeer's Avatar
Rocketeer
Redridge,
Those look fantastic, the whole interior shot is "+A1", I will opt for the "Alu" color since my interior is black, how difficult are they to install...
Old Oct 11, 2007 | 09:29 PM
redridge's Avatar
redridge
Redridge,
Thanks, the "alu" with black will look great. The install was easy, but if you're a big guy it might be a bit cramped... remember to measure 2x and drill 1x.
Old Oct 11, 2007 | 10:58 PM
gr8330's Avatar
gr8330
Tim I can see the holes really good
Old Oct 11, 2007 | 11:08 PM
Nicolaasdb's Avatar
Nicolaasdb
Tim...I don't think you need to drill holes...the badge comes with double sided tape! And how did you cover the holes after you installed the badge?? Don't you think that this brings the value of your P down??
The combination of blue with a grey interior isn't that fantastic as it is....and now you got to sell the 2 extra holes in your car...maybe you can tell the potential buyer (if you ever get one!) that the holes are for a GT3 spoiler.
Old Oct 11, 2007 | 11:09 PM
Nicolaasdb's Avatar
Nicolaasdb
Red face
oeps I forgot to add.....:ba nghead:
So you know I was only kidding! about the holes......
