Another Muffler Bypass thread
Just seems like common sense. But what do I know.
-td
Here's an old post I did on the pep boys option. It's the easiest - and cheapest - way to tell if you'll like bypass pipes or not:
https://rennlist.com/forums/showthre...ferrerid=12205
My stocks were WAY too quiet so I did the muffler bypass thing. Great sound for tracking and Saturday afternoon. Too loud for daily driving - and I did notice power loss. The car sounded more like a harley - embarassing. Went to sport mufflers (Dansk) perfect sound.
It is just like ordering from McDonalds. Would you like that small medium or large.
Original - (Yanni)
Small - 1.75" pipe - (REM - think I am superman)
Pretty tame at idle, barely can tell the difference. 3500+ nice little rasp, punch it and it will sound good.
Medium - 2" pipe (Evanesance - when the guitars kick in)
I feel the right size mod. Idle you get...this guy has something going on under the boot. 3500 + very sporty sound, not much different than 1.75" at higher revs.
Large - 2.25" pipe (Soul Asylum)
Idle is very raspy sounding, 3500+ who put a race track in the neighhborhood...
I'll be using a set of these for track use as well. Mostly for the weight savings and for a significant engine bay temp drop (per the GT3 forum guys).
I plan to do a dyno session this winter with my new engine. I hope to be able to do a few runs with the bypass pipes and get some hard data for everyone.
-Paul
-Paul
my dyno with bypass pipes and no other mods showed a super flat torque curve (like...you could almost draw a straight line it was so flat). 258 or something across roughly. i'll see if i can dig up the graph somewhere.
there's a bit of torque lost at the bottom end, but it shouldn't be a huge deal. spend less time in stoplights
Thanks Omar.
Sorry folks, I had good intentions but just have not had time for things like dyno play. Been busy with life and just taking care of the list of "things to do" on the car before spring like x51 oil pan and 3rd radiator (up next). Also wasted a ton of free time playing with my variocam+ engagement points.
-Paul
-Paul
